James Posted October 13, 2022 Report Posted October 13, 2022 I've updated the MacOS download of EScribe Suite SP45. This update makes it compatible with the MacOS 10.16 (Ventura) beta. If it didn't work for you before, download it now and it should.
Daniel G Posted October 14, 2022 Report Posted October 14, 2022 9 hours ago, James said: I've updated the MacOS download of EScribe Suite SP45. This update makes it compatible with the MacOS 10.16 (Ventura) beta. If it didn't work for you before, download it now and it should. Amazing! It works. Thank you so much!
NavyChiefRetired Posted July 11, 2023 Report Posted July 11, 2023 Escribe crashes on my M1 MacBook Air running Ventura 13.4.1. It starts reading my Paranormal DNA 250C then closes without error. Any suggestions? Thanks!
Monotremata Posted July 12, 2023 Report Posted July 12, 2023 You reminded me I haven't tested mine yet, but my Hyperion is working fine in 13.4.1 on an M2 Pro Mini... Old version of eScribe maybe?
NavyChiefRetired Posted July 12, 2023 Report Posted July 12, 2023 I've gone back to Escribe 2 SP45 but not any further.
Wayneo Posted July 12, 2023 Report Posted July 12, 2023 @NavyChiefRetired My daughter has an M1, I'll see if she'll let me borrow it. Did it ever work on that Air, or was this a first time try? I'm going to load the latest SP50 INTL version. 1
Wayneo Posted July 12, 2023 Report Posted July 12, 2023 M1 running 13.0 and SP50 INT started up just fine. She'll upgrade within 24 hours. Plugged in via a single USB A to micro. 1
NavyChiefRetired Posted July 13, 2023 Report Posted July 13, 2023 (edited) 2 hours ago, Wayneo said: @NavyChiefRetired My daughter has an M1, I'll see if she'll let me borrow it. Did it ever work on that Air, or was this a first time try? I'm going to load the latest SP50 INTL version. First time installing it on this computer 2020 M1 MacBook Air running Ventura 13.4.1. It'll start up just fine but as it's downloading the mods settings (Paranormal DNA 250) Escribe just shuts down without showing any errors. Escribe SP50 runs perfectly fine on my old Intel MacBook Pro with the same mod and usb cable. Edited July 13, 2023 by NavyChiefRetired
NavyChiefRetired Posted July 15, 2023 Report Posted July 15, 2023 (edited) Still not able to get any version of Escribe to run without crashing on my 2020 M1 MacBook Air Ventura 13.4.1. Any assistance from anyone would be much appreciated. Thanks Edited July 15, 2023 by NavyChiefRetired
Wayneo Posted July 27, 2023 Report Posted July 27, 2023 Super late reply and it worked completely fine at 13.4.1 1
NavyChiefRetired Posted July 28, 2023 Report Posted July 28, 2023 Yes, I can load the monitoring portion, but I am unable download, change, and upload any of the setting. Program crashes when downloading the settings from my DNA mod. Right when it reaches 100%... boom it crashes.
Wayneo Posted July 29, 2023 Report Posted July 29, 2023 You should open a Help Desk ticket (link in my signature line) and and they will guide you. 1 1
NavyChiefRetired Posted July 29, 2023 Report Posted July 29, 2023 Thank you Wayneo, I may give that a try. I have an old 2013 intel MacBook Pro that's working fine with Escribe for now.
James Posted June 11, 2024 Report Posted June 11, 2024 I've posted the Mac version of SP57. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=940849 1 1
Lucifer Posted June 12, 2024 Report Posted June 12, 2024 Hace # [1:hora][?:horas]}, James dijo: I've posted the Mac version of SP57. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=940849 Thanx James.
JAB Posted January 8, 2025 Report Posted January 8, 2025 (edited) Hello, I would like to share my experience installing and using the latest version of eScribe SP57 INT on my 2024 Mac mini (M4/32GB, macOS Sequoia 15.1.1). The installation process itself went smoothly, with no issues encountered during setup. However, I faced a recurring issue when attempting to connect my new (New Old Stock) Evolv DNA 100 Color device, which was paired with a brand-new Samsung 40T 21700 battery (4000mAh, ~15% charge). I used a high-quality Anker USB-C to USB-C cable to connect the device to my Mac. Upon connection, eScribe successfully recognized the device and initiated the settings download. The download progressed as expected until it reached 100%, but then I encountered a persistent error message: “Crash Log Failed – Unable to log Crash”. Clicking “OK” would return me to the main interface, but the only available option was to retry the connection and download, which resulted in the same crash each time. To troubleshoot, I switched to a Windows 11 Virtual Machine, installed the Windows version of eScribe, and connected the same device via USB. This approach worked flawlessly—the settings download completed without issues, and I was able to update the firmware to 1.1 SP55.1 INT without further complications. Given this, I am unsure if the issue on macOS was caused by the low initial battery level (~15%) or perhaps a compatibility problem specific to the macOS version or USB interface. It’s worth noting that after some time connected to the Mac mini, the device likely charged slightly, which may have contributed to more stable behavior when switching to the Windows environment. I would prefer to avoid using a virtual machine for routine updates or tweaks, so I hope future updates might address this behavior on macOS. Despite this hiccup, I appreciate the robust functionality of eScribe on Windows and the flexibility it provides once properly connected. Thank you for your ongoing support and development of this software. If additional logs or details would help in diagnosing the issue, I am happy to provide them. Warm regards Edited January 8, 2025 by JAB
John R Posted July 7, 2025 Report Posted July 7, 2025 Is there any possibility of SP67 appearing for Mac? Starting to feel like a second class citizen here..
Wayneo Posted July 8, 2025 Report Posted July 8, 2025 Open an offical 'Help Desk' ticket and relate your needs. * That SP only adds the OXVA DNA device. Link in my signature line.
