txmonkey214 Posted November 18, 2016 Author Report Share Posted November 18, 2016 Prompts new coil, yes, or no when device goes to sleep with ohms locked. SS is iffy. Ohm readings fluctuate. Have to lock ohms. Please refer to first bug, to see one source of my frustration. Link to comment Share on other sites More sharing options...
VapingBad Posted November 18, 2016 Report Share Posted November 18, 2016 Had no issues with ss or new coil prompts with SP5 myself and had a dual triple twisted build running on during the beta and since release. It could be a connection or grouping issue I had similar issues last year with one atty when it cooled over night and cranking the coil grub screws with the L shape wrench cured it. I never lock the ohms so can't really comment on that other than sorting the fluctuating res will likely fix that. Link to comment Share on other sites More sharing options...
txmonkey214 Posted November 18, 2016 Author Report Share Posted November 18, 2016 It's my new Merlin Mini. I have a Wismec notch coil in it. Plenty of room. A perfect drop-in for it. It only holds 2 ml. So, I will check the posts when this bowl is done.Funny, though. It settles down, when I override ohms. This doesn't usually happen, when it's a loose post. We'll see. Link to comment Share on other sites More sharing options...
retird Posted November 18, 2016 Report Share Posted November 18, 2016 I use notch coils and never lock the ohms. On a new coil what cold ohm reading do you get? What is your notch coil's manufacturer's stated ohm's reading? What ohm's reading did you lock it at? The notch coil uses no resistance wire for connection to atty deck. Those 2 wires connect to the notch coil that is SS316l. If your ohms are fluctuating I suspect poor connection at the deck or poor connection between the atty and device 510 connector. Does it wick well? Link to comment Share on other sites More sharing options...
txmonkey214 Posted November 18, 2016 Author Report Share Posted November 18, 2016 It wicks very well. Perfect drop-in for the wick well. I replaced the cotton with minimally processed, organic cotton. Ohms reading was .23 ohms on my meter. It is new to me. I had to remove the dual coil deck, and put the single coil deck in. It might be the posts. I have no experience with this particular tank. Every one of them is different. I had bad luck with the Theorem on my VT133. Do you think they have a "reject all wismec" program written in their code? (Joke). Link to comment Share on other sites More sharing options...
txmonkey214 Posted November 18, 2016 Author Report Share Posted November 18, 2016 The deck was a little loose. Thanks, VapingBad, and retird. BTW, I highly recommend using a notch coil in the Merlin Mini, at least with the single coil deck, with plug removed. Great flavor, and cloud production. Link to comment Share on other sites More sharing options...
