Clairenix Posted December 15, 2016 Author Report Posted December 15, 2016 Although the DNA200/250 is a crazy safe board, I accidentally made a 0.06ohm build. 6 wraps parallel SS316L 24g x2 It took quite a bit of time and was hoping to keep it.. But with that said, my mod only has 2x Li ion batteries, am I pushing it too far? Is there some place I can educate myself about this, spefically for the dna200?
VapingBad Posted December 15, 2016 Report Posted December 15, 2016 No, I have ran 0.03 ohm on 75, 200 & 250, though I prefer to stay a little higher at 0.05 ohm. The board controls the current and it is the current limit that is important at low ohms, but the current from the batteries will be lower than the current to the coils as the voltage has been stepped down.Worst case (highest battery current) is when the battery is low it needs to supply more current to make up the required power:At the coils 133 W in to 0.06 ohm gives current = sqrt(P/R) = 47.6 A, voltage = sqrt(P/R) = 2.82 VAt the batteries 133/0.98 (98% efficiency) = 135.7 W or 67.85 W per cellcurrent = P/V = 67.85/2.75 = 24.7 A
Viruk Posted December 16, 2016 Report Posted December 16, 2016 Aren't the cells in series? You're not splitting the amp load between the cells unless they're in parallel - right?
VapingBad Posted December 17, 2016 Report Posted December 17, 2016 Viruk said:Aren't the cells in series? You're not splitting the amp load between the cells unless they're in parallel - right?But you are splitting the watts between them .At the batteries 133/0.98 (98% efficiency) = 135.7 W or 67.85 W per cellcurrent = P/V = 67.85/2.75 = 24.7 Aif you take both together the low cut-off would doublecurrent = P/V = 135.7/5.5 = 24.7 A
Viruk Posted December 19, 2016 Report Posted December 19, 2016 My understanding is that you're not splitting the watts or current unless you're running cells in parallel. Please feel free to correct me, but my understanding is that each cell in the battery takes the full load when in series. This is an excerpt from a Wikipedia article that sums it up quite nicely: Series circuits are sometimes called current-coupled or daisy chain-coupled. The current in a series circuit goes through every component in the circuit. Therefore, all of the components in a series connection carry the same current. There is only one path in a series circuit in which the current can flow. I'll post the link to that in a moment - but I'm stuck on a phone while travelling...
Viruk Posted December 19, 2016 Report Posted December 19, 2016 https://en.m.wikipedia.org/wiki/Series_and_parallel_circuits
VapingBad Posted December 19, 2016 Report Posted December 19, 2016 You are splitting the watts with series batteries, just the same as with series resistors. Consider that half the voltage is coming from each P = IV/2.
awsum140 Posted December 19, 2016 Report Posted December 19, 2016 My comment is since the total voltage doubles, the current is cut in half for each battery. Yes, they still conduct the same amount of current but it is reduced by 50% because the voltage is increased by 100%.
VapingBad Posted December 19, 2016 Report Posted December 19, 2016 awsum140 said:My comment is since the total voltage doubles, the current is cut in half for each battery. Yes, they still conduct the same amount of current but it is reduced by 50% because the voltage is increased by 100%.No, current is always the same through every component in any series branch of the circuit, the current required would be halved if the voltage is doubled, but both batteries in series will have equal current (their voltages could vary).
awsum140 Posted December 19, 2016 Report Posted December 19, 2016 The current, total circuit current, is effectively cut in half since the voltage is doubled. I'm not saying that each battery only supplies half the total current, they both supply the same amount of current but it will be half that of a single or parallel battery arrangement when the output power is the same. That's why high voltage is used for power transmission, to lower the current load and allow smaller conductors to supply higher power levels. As voltage increases, current decreases assuming the same load, output power, is maintained.
VapingBad Posted December 19, 2016 Report Posted December 19, 2016 Yeah we were saying the same thing, sorry I misread your post awsum
awsum140 Posted December 19, 2016 Report Posted December 19, 2016 It gets a little "nebulous" talking about current/voltage in series and parallel circuits because the power level is maintained by the chip in the case of a DNA or other regulated mod. In the normal world, the current would, indeed, double with a doubling of supply voltage, but the chip prevents that to maintain the power at the desired level hence the current drops by half instead.
