jesseseetai Posted January 31, 2017 Author Report Posted January 31, 2017 is it okay to use enameled copper wire (magnet wire) for a build instead of silicone insulated wire? I like that the magnet wire can be formed to the creases of the box and won't move around. I've seen other modders use it for dna40 builds.
Spector NS5 RD Posted January 31, 2017 Report Posted January 31, 2017 if you're going to use it as power wires and not as signal wires (up/down/fire buttons), make sure it's the correct thickness. too thin and bye bye enamel coating, hello short city. also don't forget the positive wire from the board to the 510 moves with the 510's center spring loaded pin (if you are using a spring loaded 510), be sure to account for that back and forth movement of putting on and taking off atty's.
jesseseetai Posted January 31, 2017 Author Report Posted January 31, 2017 ChunkyButt200 said:if you're going to use it as power wires and not as signal wires (up/down/fire buttons), make sure it's the correct thickness. too thin and bye bye enamel coating, hello short city. also don't forget the positive wire from the board to the 510 moves with the 510's center spring loaded pin (if you are using a spring loaded 510), be sure to account for that back and forth movement of putting on and taking off atty's.I was planning on using 14 awg for the output to the 510. and 18 awg for the battery connections and ground.
retird Posted January 31, 2017 Report Posted January 31, 2017 Deleted.... What is the amp rating of #14 magnet wire?
jesseseetai Posted January 31, 2017 Author Report Posted January 31, 2017 retird said:Deleted.... What is the amp rating of #14 magnet wire?I found this video of a guy testing 16 awg at pretty high currents https://www.youtube.com/watch?v=HPll6fdUjnY
awsum140 Posted February 1, 2017 Report Posted February 1, 2017 If it's "heavy formvar" magnet wire the current rating will be higher than standard enamel coated magnet wire since it has a much higher heat rating.I wouldn't worry, too much, about silicon wire moving around inside a mod. Yes, solid wire can be neatly formed and look "nice", but silicon wire can also be "formed", sort of anyway, and doesn't really move much at all. Plus it gives you the advantage of being able to assemble without worrying as much about stressing battery connections. The motion of the 510 center pin is not all that great, but over time, could either break a solid wire or cause separation of the foil from the board depending on how the stress is transmitted by the wire.I used 12 gauge silicon to the 510 in all my DNA200 and DNA75 mods and basically had to pre-bend it into shape prior to actual final assembly. It still looks the same today as the day I built them, over a year an a half ago.
jesseseetai Posted February 1, 2017 Author Report Posted February 1, 2017 thanks for all the responses guys. I think I'll either go with silicone or PTFE wire. Any advantages one over the other?
Spector NS5 RD Posted February 2, 2017 Report Posted February 2, 2017 i prefer silicone wire. both the teflon and silicone stand up, pretty well, to high temps and soldering, but the teflon wins the heat battle (insulation doesn't get soft if heated). i will say the teflon wire i received, was more stiff than silicone insulated, like PVC. that's why i prefer the silicone, easier to work with.
