Cotay Posted June 27, 2015 Report Share Posted June 27, 2015 It appears that permissions aren't properly set to download the Datasheet. I've verified my account but the link states "you don't have permission to perform this action". Link to comment Share on other sites More sharing options...
magerb Posted June 27, 2015 Report Share Posted June 27, 2015 Same here. Link to comment Share on other sites More sharing options...
Justin Posted June 27, 2015 Report Share Posted June 27, 2015 I checked the permissions and don't see anything that would prevent you from downloading the attachment. Did you verify your email address? Link to comment Share on other sites More sharing options...
Cotay Posted June 27, 2015 Report Share Posted June 27, 2015 Thanks Justin. The .pdf still doesn't work, but your link worked fine. My email address has been verified and the other downloads to the beta enclosure and board files work fine.EDIT: The .pdf is now working as well. Link to comment Share on other sites More sharing options...
magerb Posted June 27, 2015 Report Share Posted June 27, 2015 I have the exact same issues. I did verify my email, still no go. Thanks for the link, it works fine!Michael Link to comment Share on other sites More sharing options...
Phone Guy Posted June 27, 2015 Report Share Posted June 27, 2015 It downloaded for me in my phone. Link to comment Share on other sites More sharing options...
AlenDjuderija Posted June 29, 2015 Report Share Posted June 29, 2015 Jup i have same problem guys, we cant download its like on uk-ecig forrum when you dont have acc and you cant see sh*** Link to comment Share on other sites More sharing options...
FJAS Posted June 29, 2015 Report Share Posted June 29, 2015 I just downloaded it and opens fine Link to comment Share on other sites More sharing options...
copyman Posted June 30, 2015 Report Share Posted June 30, 2015 Everything is working normally ... Link to comment Share on other sites More sharing options...
Jakeatadvance Posted July 6, 2015 Report Share Posted July 6, 2015 so, (and please dont stab me if im completly wrong) but according the graph, you can fire .01ohms? or is it still .05? Link to comment Share on other sites More sharing options...
John Posted July 6, 2015 Report Share Posted July 6, 2015 You can fire into .01, but it will current limit to 25 watts output with kanthal, or maybe 50 watts once a nickel coil has heated up (and somewhere in between for things in between like twisted nickel/kanthal and titanium)Also you'd really need to nail your mod and tank resistance readings to temperature control properly down that low, so it is a touch impractical to use a coil that low. Possible, but not great results. Link to comment Share on other sites More sharing options...
Mad Scientist Posted July 17, 2015 Report Share Posted July 17, 2015 I know this is a dumb question, but for the balance connector, the drawings seem to show the "slot" down (farther from the USB) but the photos show the "slot" up (closer to the USB). Am I missing something? My eyesight isn't what it once was so maybe the connector is marked somewhere but anyway, which way does it go? Thanks. Link to comment Share on other sites More sharing options...
Brandon Posted July 17, 2015 Report Share Posted July 17, 2015 The Data sheet shows 3 possible orientations for the balance connector. If you are mounting using the through holes, the slot goes down (farther from the USB). Link to comment Share on other sites More sharing options...
Mad Scientist Posted July 18, 2015 Report Share Posted July 18, 2015 Brandon said:The Data sheet shows 3 possible orientations for the balance connector. If you are mounting using the through holes, the slot goes down (farther from the USB). Thank you! Link to comment Share on other sites More sharing options...
iamiam Posted May 20, 2016 Author Report Share Posted May 20, 2016 Just got my VT75 today. I went through the tutorial but don't see anything about battery setting. Do I need to input battery information anywhere if I'm sing a 18650? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted May 20, 2016 Report Share Posted May 20, 2016 under the mod tab in escribe make sure you have lithium ion 18650 selected and set your cell soft cutoff to not less than 2.6if you want to to input the watt hour of a battery, run battery analyzer. there's a box you can also check if you plan to use an external battery charger. Link to comment Share on other sites More sharing options...
VapingBad Posted May 20, 2016 Report Share Posted May 20, 2016 I don't bother changing any of the battery settings and it works well with 25Rs. Link to comment Share on other sites More sharing options...
Mangiman Posted May 20, 2016 Report Share Posted May 20, 2016 This new chip runs on 3s LiPo or 2s or 1s ??? Link to comment Share on other sites More sharing options...
awsum140 Posted May 20, 2016 Report Share Posted May 20, 2016 The DNA75 runs on a 3.7 supply voltage, 1s. Link to comment Share on other sites More sharing options...
iamiam Posted May 20, 2016 Author Report Share Posted May 20, 2016 ChunkyButt200 said:under the mod tab in escribe make sure you have lithium ion 18650 selected and set your cell soft cutoff to not less than 2.6if you want to to input the watt hour of a battery, run battery analyzer. there's a box you can also check if you plan to use an external battery charger.Thank you . There was a "Manufacturer Settings" under the Mod tab which I missed the first few times. I'm using Sammy 30Q with the cutoff value of 3V and Max Input @ 20A and Pulse Input of 30A. Or is there a list somewhere of all manufacturer specs? Link to comment Share on other sites More sharing options...
Mangiman Posted May 20, 2016 Report Share Posted May 20, 2016 Anybody knows where to get a LiPo 1s with xt60 connector and does the micro usb port on board will charge it? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted May 20, 2016 Report Share Posted May 20, 2016 Mangiman said:Anybody knows where to get a LiPo 1s with xt60 connector and does the micro usb port on board will charge it?www.hobbyking.com has lipos and connectors. the dna 75 has an on board 1 amp charger that is powered from the micro usb port. Link to comment Share on other sites More sharing options...
Mangiman Posted May 21, 2016 Report Share Posted May 21, 2016 Can i use a 6400 MAH 1s LiPo with 90c or should be below 90c? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted May 21, 2016 Report Share Posted May 21, 2016 Mangiman said:Can i use a 6400 MAH 1s LiPo with 90c or should be below 90c?you could use that lipo. the 90c rating is fine, overkill, but fine. the board only draws 30 amps max. a 30c will even do. but yes the lipo you asking about WILL work. Link to comment Share on other sites More sharing options...
olafeone Posted August 12, 2016 Report Share Posted August 12, 2016 Can anyone tell me what to put in VT75 for my AWT 26650 3.7V 4500mAh 75 A battery plz ? Link to comment Share on other sites More sharing options...
