jsayers Posted September 24, 2016 Author Report Share Posted September 24, 2016 I have a recently purchased Therion DNA75 I am having issues with it in temperature control. All of my wire is SS316L at the moment so that is in all of my builds. No matter which RDA , RTA or build I use the board reads "OFF" when I press the fire button. The mod stills fires, I assume with straight wattage as if it was in Kanthal mode. All of the builds work fine on my Triade so I can't see that being an issue. I have tried different gauges of wire and resistances between .16 and .4 without success. My gut tells me the 510 or board connections might be suspect. I have not tried a hard reboot but that might be my next move. Lost vape said they would repair it but the turn around is 3-4 weeks. If it could be something simple I would rather fix it myself than lose it for a month. Anyone else have this issue? Link to comment Share on other sites More sharing options...
jsayers Posted September 24, 2016 Author Report Share Posted September 24, 2016 Never mind, I just saw the earlier post on the same issue. Going to load up a new profile now! Link to comment Share on other sites More sharing options...
retird Posted September 24, 2016 Report Share Posted September 24, 2016 Is Temp turned off in your profile? I guess you have Temp Dominate checked in the profile... Link to comment Share on other sites More sharing options...
jsayers Posted September 25, 2016 Author Report Share Posted September 25, 2016 Uploaded the ss316L csv from DJaquith V7 and problem is solved!! The csv from lost vape was all jacked up! Thanks forum!! Link to comment Share on other sites More sharing options...
jurdanas Posted September 25, 2016 Report Share Posted September 25, 2016 Evolv SS316 curves work well, to me, no need speed. Link to comment Share on other sites More sharing options...
2legsshrt Posted September 25, 2016 Report Share Posted September 25, 2016 From what I have heard the profile for SS316L from Lost Vapes was way off. I did like you and changed that profile as soon as I got it. I used the .csv from Steam Engine which worked well for me. On the Therion thread at ECF so many complained about the profile I didn't even bother with it. But I use SS316L in TC works perfectly. Link to comment Share on other sites More sharing options...
cgagne Posted March 31, 2017 Report Share Posted March 31, 2017 What was the fix for this? Are you not supposed to have temp dominate checked? I'm using ss316l from steam, and it reads off no matter what build or atty. Link to comment Share on other sites More sharing options...
giz_60 Posted March 31, 2017 Report Share Posted March 31, 2017 cgagne said:What was the fix for this? Are you not supposed to have temp dominate checked? I'm using ss316l from steam, and it reads off no matter what build or atty.Can you post a couple of screenshots from Escribe...'Mod' tab & the device monitor while firing with the following boxes checked...power, power set, temperature, temperature set, cold ohms & live ohms... Link to comment Share on other sites More sharing options...
cgagne Posted March 31, 2017 Report Share Posted March 31, 2017 I definitely will. I work night shift, so I'll probably get a chance to post on the morning.....Thanks ! Link to comment Share on other sites More sharing options...
giz_60 Posted March 31, 2017 Report Share Posted March 31, 2017 Link to comment Share on other sites More sharing options...
cgagne Posted April 4, 2017 Report Share Posted April 4, 2017 No matter what I do, what settings I change, when I run the device monitor, temp doesn't even register. Temp control doesn't work. Link to comment Share on other sites More sharing options...
giz_60 Posted April 4, 2017 Report Share Posted April 4, 2017 'Off' means the device is switching to Power mode...your resistance is not stable...first screen shot, .330...second screen shot. .335 & while firing, it should never drop as it is in both screen shots...make sure atty is cold before setting the cold ohms...need to check all connections...tight screws...clean 510 (atty & device)...Mod resistance needs to be checked & set...case analyzer needs to be run...the device HAS to be set up properly in order for TC to work...especially when using SS Link to comment Share on other sites More sharing options...
cgagne Posted April 4, 2017 Report Share Posted April 4, 2017 I've cleaned everything with rubbing alcohol. The screws on my goon 24 are as tight as I can get them. Mod resistance says zero? And unfortunately all the other stuff is like speaking Spanish to me. Lol. It just sucks, I like temp control, but wish I didn't get a dna. I didn't realize it was going to be this difficult. I need a cigarette after every time I mess with this thing....smh. kind of defeats the purpose. Link to comment Share on other sites More sharing options...
cgagne Posted April 4, 2017 Report Share Posted April 4, 2017 I appreciate you trying.....im just hopeless. Plus it doesn't help I'm computer illiterate. Link to comment Share on other sites More sharing options...
cgagne Posted April 4, 2017 Report Share Posted April 4, 2017 In the battery part. I'm running 25r's and LG brownies.....should my capacity be 18.5? Cell soft cutoff 3.09v? Link to comment Share on other sites More sharing options...
cgagne Posted April 4, 2017 Report Share Posted April 4, 2017 Battery Link to comment Share on other sites More sharing options...
giz_60 Posted April 4, 2017 Report Share Posted April 4, 2017 Cell soft cutoff 2.8, but thats not going to make any difference in the TC issue...Mod resistance setting in 'Mod' tab...read this thread starting at about post #72...https://forum.evolvapor.com/topic/65594-topic/Case analyzer is at the bottom of the 'Mod' tab...just make sure your batteries are at least 50%..or less before running...Edit: Unfortunately, the device manufacturer's don't set up all the variables to get a good TC vape, but once you have everything set up, it will work great... Link to comment Share on other sites More sharing options...
cgagne Posted April 4, 2017 Report Share Posted April 4, 2017 Oh, I know the battery stuff doesn't effect temp control. I just wanted to make sure my settings are correct. The first time I hooked my mod up to e scribe it seemed like a bunch of my settings got screwed up. Like it got changed to 3 cell. I didn't know if anything else got changed because I don't know what the settings are supposed to be. I can't seem to find anywhere to explain any of this in "English". Link to comment Share on other sites More sharing options...
cgagne Posted April 4, 2017 Report Share Posted April 4, 2017 Yeah I see where the case analyzer is and what not but I don't understand what it is and what it does after I do it or what It's trying to tell me. I'm just going to use the mod in wattage mode but I wanted to make sure the battery part was working correctly. Link to comment Share on other sites More sharing options...
cgagne Posted April 4, 2017 Report Share Posted April 4, 2017 Wow. Smh. After reading that.....im even more confused. I didn't understand anything I was reading. The only thing I maybe got from that is, if I want to use my goon, instead of my Merlin mini, I have to hook this thing up to a computer and change all my settings? Link to comment Share on other sites More sharing options...
cgagne Posted April 4, 2017 Report Share Posted April 4, 2017 Like my batteries were just at 100%. I've used it for 2 mins and it says 83%. I'm using 45 watts and took 4 toots.....17% battery used..... I really think all my settings got screwed up. I wish there was somewhere I can go where it will tell me what they're supposed to be Link to comment Share on other sites More sharing options...
giz_60 Posted April 4, 2017 Report Share Posted April 4, 2017 Evolv has a really good hands on training tutorial here that might help ya out some...https://downloads.evolvapor.com/escribe/guide/story.htmlThere are also quite a few videos on YouTube about Escribe & setting up the DNA devices..just search 'Escribe' on YouTube... Link to comment Share on other sites More sharing options...
cgagne Posted April 4, 2017 Report Share Posted April 4, 2017 Yea, I've watched a bunch of videos, read a bunch of forum stuff. Idk, I'm still not comprehending it. I work crapy hours, and have 2 kids. I barely have time to sleep. I didn't realize so many factors would matter just for me to vape. What day it is, the weather outside as opposed to inside, if I'm left/right handed. Lol. I just want to know what numbers go with what settings, so I can press fire and vape. I don't have time to take my laptop out and change settings every time I want to change my atomizer, or the weather changes. I appreciate your attempt to help me, but I think I'm a lost cause. Just sucks. The 2 days my mod worked in temp control.....i loved it!!! Then I plugged it in to escribe......never worked again. 1 Link to comment Share on other sites More sharing options...
cgagne Posted April 4, 2017 Report Share Posted April 4, 2017 Plus, they have the pre loaded profiles....it worked for those 2 days....they say I shouldn't have to use e scribe. Only if I want to make adjustments. I don't care about adjustments right now....i just want it to work. Link to comment Share on other sites More sharing options...
giz_60 Posted April 4, 2017 Report Share Posted April 4, 2017 I just noticed in your screenshots that the Escribe version is for the 250...do you have the Therion 75 or 166? Link to comment Share on other sites More sharing options...
