Everything posted by Thunder Dick
It sounds like you might have had a tiny piece of solder bridging something on the board somewhere. When I suspect something like this I take a jewelers loupe and look over every single bit of the pcb in question and I will do this 2 , 3 , 4 maybe 5 times until I can be 100% positive with no doubt that I would have found it if that was the problem. And I have been surprised by what I have found before even straight from the factory with some pcb's .
I meant what I said your themes really are awesome. The best thing about your themes is the diagnostic capabilities. I have dealt with a lot of themes that have problems in them when you download them and then you have me the 200 pound gorilla messing with stuff I don't understand and it doesn't turn out good . Let's just say there's a lot of swearing trying to figure out what is wrong and you end up chasing your tail and it can get frustrating. Then you come along with the answer to that problem. They should construct a statue of you or maybe even make a new holiday in your honor. But all jokes aside there are really helpful features and you did a great job on them and anything that makes using the DNA chip easier is awesome. How did you come up with that feature anyway because like I said it's probably one of the most useful things I have seen someone put into a theme. A+ you get a gold star ⭐
This theme is the man . It has features that I haven't seen in other themes. Every theme put out by this guy is worth having no your box . It may sound stupid but the biggest problem is coming to a decision of which one of them you are going to use . aMirS I made some small changes like a font change for the number displays and changed the color of a few icons but thank you for doing the really hard part. You put a whole lot of time and effort into what you have created and it shows. It sucks they only have 5 stars because you deserve more thanks for sharing with everyone.
Do you have pre heat on ? If you do and the pre hat temp is set low it will make it seam like it fires slow .
Happy new year to you as well . When you solder that so you don't burn the ribbon take a small piece of foil and place it on top of what you are soldering that should help with keeping the ribbon in Good shape and let me know if you end up needing this thing it isn't going anywhere so it will be here if you do
Well like I had said in the other post if you were willing to get a new ribbon cable connector and solder it in yourself. Then skip the connector and solder the little contacts that are left of the knackered clip directly to the ribbon cable. It's very easy to do get some low melting point soldering paste and spread some on the ribbon and place it were you want it and heat it with the hot stick. I'm not sure how much time you have had working with a soldering iron but the one thing to be aware of when using soldering paste don't use it like the bigger the gob the better the job mo paste don't mean mo better . Use only a little and it will all flow to the meatal to metal joints and won't leave any solder between joints to short on out your hard work. I don't know about you but when I dump a bunch of effort into something and something like solder crossing over pads and shorting out ruins as ll no that effort. As if by magic that project takes flight across my shop hits the wall and breaks itself down into smaller pieces . If you try doing something like this the worst that could happen is the broke connector stays broke and you are out a couple dollars sorry I meant quid for a screen . I have to been working on electronics for most of my life and that is what I would do if I were in your situation . But the whole board is still there if that's path you want to take and there is absolutely nothing wrong with it I thought it was was acting up so I swapped it with a new one and the same things were happening . Ask it turns out it was the cheap coils I bought trying to save a few cents . It hasn't started the magic flight yet though .
Are you sure it's broke I pulled out an extra board I have and it looks the same that part pulls up to let the ribbon in or out . My brand new board looks just like that when putting the ribbon in make sure it's in all the way or that part that lifts up won't stay clipped but that part is supposed to lift if you look at the ribbon it has a notch on each side that is how it's locked in place once you push that little hinged piece back down .If you want I have an extra 75 c board I could probably sell you but I don't know how we would work that out. If you look at the part you could desolder it and solder the ribbon directly to the board just use low temp solder paste and it should work fine or solder the ribbon directly to the pins I would try that first.
Need Some Help With Icons
Thunder Dick replied to TheCloudCartelUK's topic in Themes and Custom Screens
If you see this check your emails I sent you all the icons sorry it took so long but better late than never right -
- 48 comments
- english + deutsch
- replay
(and 4 more)
Tagged with:
Sorry it's taking so long when I sent the other icons my flash drive was corrupted I'm putting my collection together again so I will get them to you in the next couple of days and sorry again for the delay -
Where would you like them to be sent? -
I had a theme i was working on myself but stopped using it because it was having problems . Using this helped me understand some things to look for to fix my own theme. I have used themes in the past that always had the temp protect warning pop up and didn't know why. If you are having temp control issues or issues period check this out it might help you get to the bottom of those problems that have been driving you crazy
A DIFFERENT WALLPAPER DOES NOT A NEW THEME MAKE
Thunder Dick replied to Thunder Dick's topic in DNA 250 Color
I really need to pay more attention didn't even realize cap lock was on people probobly think I was doing it to be a butt pipe . Saw your comment had to go back to see what you were talking about. -
I DON'T UNDERSTAND WHY PEOPLE POST THE SAME THEME WITH DIFFERENT WALLPAPERS SO MANY TIMES . I'M NOT TRYING TO BE MEAN BUT THERE IS NO REASON TO SIFT THROUGH THE SAME THEME 20 TIMES . YOU CAN POST ONE TIME AND HAVE A LIST OF ALL THE WALLPAPERS YOU WANT WITHOUT THE USELESS CLUTTER. THERE ARE SOME PEOPLE WHO POST THE SAME THEME MULTIPLE TIMES BUT THEY ARE STREAMLINING THEIR THEME AND EVEN THOUGH IT LOOKS THE SAME IT ISN'T. THESE UPLOADS ARE UNDERSTANDABLE. IF PEOPLE AREN'T DOWNLOADING YOUR THEME POSTING IT 20 MORE TIMES WON'T CHANGE ANYTHING. LIKE I SAID NOT TRYING TO BE MEAN AND STIEFEL ANYBODY'S CREATIVITY. I JUST DON'T SEE WHY YOU DO IT.
I have a huge collection of icons probably over 1000 would you like me to send them to you ? -
replay EZ-Replay DNA250C Theme
Thunder Dick reviewed DONG_MAGNUM's file in DNA 75 Color, 100 Color, 250 Color
Concept - Blue Wall Texture
Thunder Dick reviewed BMan1959's file in DNA 75 Color, 100 Color, 250 Color
I DON'T KNOW WHY YOU UPLOAD THE SAME THEME OVER AND OVER SO PEOPLE HAVE TO SCROLL THROUGH 100 COPYS OF THE EXACT SAME THING , THE ONLY DIFERENCE BEING THE BACKGROUND . IF PEOPLE LIKE YOUR THEME THEY WILL LOAD IT , AND IF THEY DON'T LIKE THE BACKGROUND THEY CAN CHANGE IT . YOU KNOW YOU CAN LOAD A THEME AND GIVE THEM ALL THESE COICES IN ONE UPLOAD . IM REALY NOT TRYING TO PUT YOU DOWN OR ANYTHING I UPLOADED YOUR THEME . AND YOU AREN'T THE ONLY PERSON THAT DOES THIS SO WHEN YOU GO TO LOOK FOR A THEME YOU LIKE AND YOU SEE THE SAME THEME MULTIPLE TIMES IT'S EASY TO OVERLOOK OTHER COICES THAT MAY BE IN THE MIDDLE OF YOUR LIST BUT ALL THAT ASIDE YOUR THEME IS GREAT -
THIS IS ONE OF MY FAVORITE THEMES I CHANGED IT TO LANDSCAPE AND MADE SOME ICON CHANGES I WAS WONDERING IF IT WOULD BE OK TO POST IT I WILL GIVE YOU ALL THE CREDIT FOR IT SINCE YOU WERE THE ONE WHO HAD TO DO THE HARD WORK AND ILL LET YOU SEE IT BEFORE HAND SO YOU CAN APPROVE IT THANKS FOR ALL THE HARD WORK YOU DO ON YOUR THEMES
Hi again just updating you with what has happened with the error message I was flipping through options in the menu and I don't think it is your theme that is giving this error message I noticed that it only happens when you flip trough the options in the menu really fast I am thinking that it is the board having trouble keeping up with the rapid movement trough the options that is the only time I can get this message to pop up maybe I'm wrong but that is what I think is causing the problem and I am really enjoying the new theme Tausend dank
- 3 comments
- up to 4 batteries
- powerbank
(and 1 more)
Tagged with:
