a_sane3
Everything posted by a_sane3
  1. what about this one????
  2. hi i have same issue did any body find a solution? thank you
  3. hi i have same issue did you find any solution?
  4. no . did you contact ginger vapor? if yes what did they say? thank you
  5. if it software problem when the firmware will relese?
  6. thank you the problem is iam not a us residence the problem is i buy the mod from vapor dna and they say you have to contact ginger vapor because there warranty only 45 days and when i contact ginger no body answer
  7. no body reply :(((
  8. where can i find the alpha/Beta version?
  9. yes mine is.so plz tell me how you solve the problem?
  10. did you find a solution?
  11. you mean if i change a theme it may be ok?
  12. same happen to me. i have same issue
  13. boxer squonk 2x20700 battery dna250c
  14. i know mine was fffff i press 5 times fire it does not unlocked plz dont try to make me uggly.... and what about check atomizer ? this is my last issue plz tell me how to solve it
  15. Thank you for reply 1- i did not use any customizable themes still mine is defult. 2-i see videos otherwise i did not use any of of these customizable options iam just using watt mod and replay mod with ss coil first issue the device can not be unlocked then then after reboot the battery drain then i reboot temp protect last issue check atomizer and the issue not with the atomizer because i try many many of them. and one more thing now when i try to reboot it gave me hard reboot issue and about whos support you contact i contact evolv and open three tickets do you want there no.?
  16. whats going on with dna 200c every day new kind of error first can not unlock then battery drain and then temp protect even iam on watt mod and every thing is ok!!! and last error check atomizer i use different atomizer same issue when all these problem will be solved ?? because right now my mod is useless even it is only two month old i contact the technical support no body answer could some one give us any info :((((
  17. i got temp protect even i in wat mod then get check atomizer i try many same problem mine boxer device also
  18. new error in mine temp protect and check atomizer in defult watt settings above 20 watt i try many atomizer same problem
  19. where can i find the beta version?
  20. finally i find a solution it may help you downgrade the s.p. to 33 and then do a hard reboot it may work with yours because it work with me thank you
  21. Every thing that you mentioned it was been tested
  22. I open ticket 4 days ago no body answer:(
