Everything posted by VapingDad
Just got my paranormal 166 want to get 316l for tc any help
VapingDad replied to Dtgodmage22's topic in DNA 200 and 250
There was no lock tight on it it was just a loose connection Oni uses identical shit as the paranormal. So any Intel I give for one vape I applied to others. Also fun thing my paranormal was charging overnight on the USB port onboard and now won't fire up so I've had it with this piece of shit it's going back. I've had nothing but issues with lost vape products and they are just shit from my experience. Their product failed their performance review but they look nice but that's it -
Therion DNA 250 166W - (Check Battery)
VapingDad replied to Doblos's topic in Batteries and Charging
Same issue with lost vape paranormal 166 but interesting twist push and hold power/fire button and device Powers up but says check coil(no atty) or check batteries let off fire button shuts down -
well looking at that quick fix i thought id take a look at the settings and well im sold, because now running 6 wrap stainless 316 24GA twisted with a 0.635 twist is now working perfectly in the sherman RTA and the combo/ijoy RDTA. im now wondering if there is a simular fix for the the oni 167 because that worked perfectly. the 510 deck was a 1/2 turn off therefore no solid connection... who knew that these things are damn near rocket science to fix -
coils are fused clapton stainless steel core 24g wrap 30g, 6 wrap on 3mm wrapping tool. rated at 0.17 ohm. i will also look at page 1 as for firing in device monitor it doesnt even detect the coils as temp just watts. update my computer doesnt do screenshots -
according to my local vape shop building in temp control its one touchy item to work with. i too am having issues -
im having the same issue and its pissing off me and my local vape shop im using the Sherman Tank RTA by Asylum mods. its a great tank but temp control does work ONLY when the coils are dry for some strange ass reason. if anyone can assist with this also as for the screenshot of the device monitor, the device fails to read the actual temp of the device. screen on the dna states "OFF" i get 3-4 drags when its on 410*F so im using it basically at watts till anyone can get a perminate fix. i also have the same issue with a ijoy/combo rdta on an oni 167 ive started to come to the realization that the dna chips are just garbage. sure you can mod the themes and make it look fancy but big whoop if a device thats advertised for temp control and you go to use it in that way but nope good luck hope you like having a device not work for that setting -
What's best???
SS316L Fused Clapton 24*2+32
Thanks for the extra ideas, sorry it took so long to get back to this I recently upgraded my mod to another DNA 250 but I've just been way to busy with work to even think about or having time to continue with the project.
Maybe in 2014 battery changes it's the end of the world, the way your wording what's happening is that Everytime you change batteries you go back a year like a count down.
So your DNA is stating that they are at 7.xx but are they rated for something closer to the 5.xx mark I believe. If this is the case I'd tighten down the coil(s) and the 510 pin. Also check if the spot where you thread in the atty is wet that can and will cause issues. I build my own coils and I have a little difference in ohm reading Coldcoil 0.15 Warmcoil 0.16 Hotcoil 0.17-0.18 It's a minor increase but it's liveable now if jumping from 5.0 - 6.0 then that's a whole ohm going out of whack which could be the atty, coils, mod or all the above I've had that issue with kanthal wire but I rarely get it with stainless.
No problem, also I recommend using escribe for working and tweaking the dna it's easier to change multiple profiles with ease with escribe
These things know the date??? Cool.
Also send them your complete mod profile so they can replicate the issue. Should be in the general tab
Did it work if not connect it to your computer in escribe and memorize the battery stuff or screenshot it then factory reset it. Please do this at last resort because you will definitely loose everything
Also what are your standing(cold oms(quick press(tap)the power(fire) button)) you may just have to tighten the coil posts and/or the 510(center) pin
Thanks I went to my vape shop and downloaded all battery profiles from them.
In the escribe software I think in device monitor you can override all puff limits but only for testing purposes (while connected to computer I do that on mine but I select 1-3 sec testing limits to not burnout cotton if your dry firing on the other hand it works as long as you want just try not to add too many 0's as you don't want to inhale for an hour or something lol This is in the GUI version that I use of escribe
SS is an abbreviated term for STAINLESS STEEL the most common kind of SS I've seen is ss316. To change materials lock your mod (5x click on power(fire) button) now press and hold fire,+&-. (All buttons) for about 5 seconds then use + or - till you see ss316 which is commonly preloaded into your DNA. If it's not in there I'd recommend finding the correct file or if you can wait till the end of the day I can upload the file for you as I've already acquired the ss316 profile. Hope that helps
Sorry for the long ass post. The two main errors I get are "oms too low" & "short out" and yes I have checked the shit out of the batteries they are brand new
Hi everyone, I just bought a lost vape paranormal mod and the Sherman tank RDA to upgrade my style from the ijoy RDTA on the starrs 168 neochrome both use the 250 DNA chip. Now here's my strange issue. Got everything built on the Sherman 7 wrap with ss316 (Clapton dual core) the whole dry firing worked no problem. Do the wicking and test firing and now my paranormal is stating that there's low oms, and it's shorting out there's lots of clearance around all the coils so that can't be the issue, I checked the 510 pin on the vape still nothing. Now here's where things get a little interesting. I put the Sherman from the paranormal to the starrs neochrome the Sherman works with no issues. The ijoy works nicely on the paranormal. I want to know why it isn't working when I want to use the paranormal mod with the Sherman deck because they look beautiful together. Coil build: 2x SS136 dual core Clapton on a CW30 (3mm) 7 wrap readout reads between 0.17-0.22 which my local vape vendor has assured me is normal. If anyone can assist me with this issue it will be greatly appreciated. As I don't want to send it back to the lost vape company.
hi i have a starrs dna 250 vape and im having a little trouble with the battery specs. I use 2x 18650 at 2500 mah, with 3.7v inserted i think, how do i get or make a csv file for those batteries. any and all help will be thanked. i already know about the mod tab, and the what-hour calc i need a discharge profile for my batteries, they are all the same they are INR18650-25R SAMSUNG SDI 5 2G93 at the top they have I1C7, J5G9 49C41 That is all the info i have on these batteries i just need help getting a discharge profile that is accurate and a good soft cell cutoff im currently set a 3.20V for the cutoff please help what you can thanks in advance
not bad, i think its easier to program themes if you own that kinda vape to test it and make sure it looks good, im more experenced with dna 250, hope they make a color screen for that chip
lol whoops well its my first time using this thing didnt know how it really worked
the theme that I'm slowly working on with inspiration from some other fallout themes is a pure vault tec theme, i will upload what i currently have they are free to use but please don't steal it as your own that's all I ask Bootloader second screen (google for pixel art) no atomizer relaxed mode main mode not decided yet (borrowed from gif) change material coil cleaner (borrowed cloud) locked out (borrowed vault Door) new coil power control return to researcher power locked out (borrowed) short out (borrowed) temp lockout (borrowed) temp protect overheating (borrowed mushroom cloud) some of these have been smoothed out and some are fully custom, i'm not saying that i stole any of it and calling it mine the ones that have "(borrowed)" are minor edited like text type, size, or just smoothed out. the ones that are not marked as borrowed are my own creations... if there is one or 2 here that i forgot to mark im sorry. the ones that are marked as borrowed i haven't thought of anything to put in place so its my own theme, if you have any suggestions feel free to let me know.
