macz
Everything posted by macz
  1. D stands for Display if not mistaken, DNA200D = DNA200 is the same board
  2. You could just PM them straight after your 1st offering post actually but since you made up your mind, then
  3. Correct Crushkrew, beta mod using Fullymax 900mah. Brandon/John posted somewhere in the forum.
  4. That's lipo too big to into beta enclosure unless you make some adjustment. Beta enclosure 94mm in heigh and that 5000mah is 150mm.
  5. Ta for the reply John, Could you direct me toward some higher quality batteries available in the Uk? Don't mind if they cost a bit more - just concened about the dimensions for the enclosure and the batteries not being too long A list of batteries tested and the results would be very helpful if you are able to provide that. What have your tests shown for higher C rating batteries? Maybe a group buy of good quaility batteries would be possible[/QUOTE] Gen Ace/Tattu maybe this is what you looking for https://www.electricwingman.com/gens-ace-lipo-batteries.aspx http://www.fast-lad.co.uk/store/index.php?manufacturers_id=240
  6. Thanks Brandon, found another refer to video below. Maybe I should compile everything in the next post or something [video]https://vimeo.com/132201523[/video]
  7. There are pin numbers on the board (manual pg 15) and the connector spec can be found http://www.jst-mfg.com/product/pdf/eng/eXH.pdf.[/QUOTE] I'm getting 404. Looks to be bad link.[/QUOTE] This should be http://www.jst-mfg.com/product/pdf/eng/eXH.pdf VapindBad forgot to remove . at the end of pdf
  8. The Custom TCR's "Click the Coil Material: combo box" section, Coil Material drop menu auto closed after I clicked it and won't give me an option to select Custom to continue. Tested on Firefox and Chrome, getting same issue.
  9. If not mistaken they're using Fullymax 900mAh, 30C, 3S lipo pack, do correct me if I'm wrong
  10. Ah okay, tbh I got no issue with one I linked for my DNA40 build. Anyways let's get back DNA200 fuse, ignore that DNA40
  11. Thanks Mamu, I have this one http://www.digikey.com/product-search/en?vendor=0&keywords=MHP-TA15-9-77 instead of the link above. I used those for my previous DNA40 lipo build Specs shows the same, just parts number are different. Will this work?
  12. I think that's what Mike had in mind, add another fuse without going through that. I assume Evolv can replace the onboard fuse for us if we unable to replace it ourself?
  13. Any plans for Mac version?
  14. Just about to reply that, I was 3 seconds late
