macz
Everything posted by macz
If not mistaken Hammond 1590G http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR1.TRC0.A0.H0.X1590g+cnc.TRS0&_nkw=1590g+cnc&_sacat=0 and for faceplace you can get it from here http://www.shapeways.com/product/2SDPD4J3Q/dna200-faceplate-with-screen-holder-and-buttons?li=user-profile&optionId=57361418
Mod just stopped working without being plugged in.
macz replied to Darklyspectre's topic in Report a Bug
http://www.mouser.com/ProductDetail/Schurter/3413033222/?qs=sGAEpiMZZMtxU2g%2f1juGqdarebAki7BncFR0viL77ps%3d = $0.54/ea Digikey Schurter - $1.10/ea -
Cotay, my DNA in general tab
Well, for me that is an inconvenience. I don't want to have to think about it all the time. There comes a time when you're halfway through the day and you're out of power. With a phone you can plug it into the charger and start using it right away. You can't do that with an APV.[/QUOTE] Do you mean vaping while it charging? You able to do that with the 200's
Search on eBay for spacer tubes, you can cut them with dremel if too long.
This has been answered by John here /topic/67888-topic/?do=findComment&comment=911156
Battery life on the Fully Max 900 battery running at 100-120
macz replied to scoopy's topic in Batteries and Charging
What I mean by 20-30mins max if you're planning to vape every 2-3mins. -
What mod are you vape on at 100w-120w? -
Probably will last 20-30mins max -
@antyac2108 has similar issues here /topic/68422-topic/?do=findComment&comment=915342
I think best that you PM mamu directly, she should able to answer your question @mamu
She's using onboard button, the set comes with the 3D printed button actuator
Here you go DNA200 Faceplace with Button and Screen holder
[QUOTE=reganbranch]what does the c mean? I.e. 30c 25c 40c [/QUOTE] [quote] C in C Rating stands for capacity. To break it down to its simplest terms, the C rating is the maximum safe continuous discharge rate of a pack. If you see 10C on your battery, it means it can be discharged at 10 times that pack's capacity. Capacity refers to the milliamp-hour rating of the battery, which will be listed as a number followed by mAh (2000mAh, for example). Here's the easy way to find your battery's discharge rate just multiply the number from the C rating by the pack's capacity. Keep in mind that 1000 milliamps equals one amp. Here's an example, using an 11.1V 2000mAh 10C 11.1 volt 2000mAh -10C 2000 milliamps = 2 amps 2 Amps x 10 = 20 amps continuous discharge [/quote]
It's mamu's guide and I just shared them here. Even that dna30 videos above made from mamu's PDF guide.
Fullymax 900mah 30C, MaxAmps 800mah 40C and Turnigy 950mah 25C(dremel work needs for particular lipo) will fit in 1590A. Mamu made a tutorial for DNA200 1590A but side panel instead of front. http://www.mamumods.com/tutes/dna200faceplate-howto.pdf
He measures all the holes to line-up properly before he cuts/drills them.
Suggestion: Finer Temperature Adjustments
macz replied to Pig's topic in EScribe, Software and Firmware
Seems fine to me http://evolvapor.forumchitchat.com/file?id=2358431 -
Lol sorry about that
Protovapor DNA200 VapeDojo DNA200 Edit: links fixed
You either create a new thread or go HERE and select suggestions.
Check the Charging Brightness in Screen tab on EScribe, if 0% set to at least 35% or higher for it to show up
Did you try on different USB ports or on another PC? I have similar issue but after I tried on another PC it works.
Is that case go here for RMA
Try remove the board from the enclosure and fire it via onboard buton directly, see if still continue firing after letting it go
