Mad Scientist
Everything posted by Mad Scientist
You are right of course. But I vape pretty much all day, about 20+ml per day at 100 watts preheat, 75 watts setting and around 45 watts at the "ebb" of each draw -- so that's my point of reference and comparison. At 20 watts to get only 4 hrs use from 14+ Wh, that would be some pretty heavy duty vaping. But again you are right -- the guy might just chain vape like a boss then wonder why the battery gets drained lol.
I guess there is a misunderstanding. What I suggested was to contact your mod vendor because your battery pack is likely no good. Nothing to do with any settings. Wish I could give some other ideas but that seems to be the problem.
Hotcig DX200 stopped working after less than 2 days use.
Mad Scientist replied to Ramrod's topic in DNA 200 and 250
I have found this specialized tool is also effective to remove pressed in 510 connectors. Place the frame over a hole in a block and give the 510 a few good whacks from the back side. -
I would contact the vendor. Sounds like your battery pack might have issues. I vape all day at around 45 watts on a 17+ Wh pack with some capacity left over at the end of the day. 20 Watts on a 14+ Wh pack should last a lot longer than 4 hours.
That is a tight fit. Very well done.
At some point, I guess I don't see why there couldn't be a power profile curve similar to TCR curve and battery discharge curve. X axis is time and y axis is wattage. Enter the values and it fires following the entered power curve. Unfortunately, I think that would sort of negate the whole concept of the board. Non-TC wire support seems more of a legacy compromise. For me, I can't taste anything from any variety of wire I've tried. I use a build that balances cold resistance in the range that works with surface area for the vape I want using wire material with a sufficient TCR at vape temps. For now Ti is best at that.
I think you guessed right. You definitely seem to have detached a resistor. Also, the ground wire on the balance pad looks to have a stray strand sticking out. Doesn't seem to be touching anything else but needs to be cleaned up so it never does. The photo isn't clear enough to tell for sure but you might be able to reflow the torn resistor back to the pads. OTOH, if a trace is damaged, the board is likely done.
Hi Mike, Looks like you need a few more lol.
Must just be you lol. Been using dual 18650 with no issues. Evolv made it public enough on this forum that I could build it. I guess I don't understand exactly what data you're looking for. I've experienced no instability and only feature lost is a full 200 watts for the 133.
As another idea, increase the surface area of the head of the screws. Solder or silver solder the screws to thin pieces of steel as a "sled" then use the preferred adhesive on the steel to mount in the box.
Is that going to be commercially available? Looks great.
Please put a Temp Lock option in software!!!
Mad Scientist replied to Droopydroors's topic in EScribe, Software and Firmware
Here's an example of a "runaway" coil: Test setup: plume veil with .005" type-E thermocouple fitted to central wrap of 3 wraps 26 AWG Ti; Ocean Controls thermocouple board with added PIC12F675 programmed to interface to PC (the 8 pin PIC is in a 14 pin dip socket because I might go with a 16 series PIC down the road). The PIC reads the temp and sends ASCII csv values to the PC. These are then saved to .csv file and charted with Excel. Data points are 100ms apart (10 per second). Data is presented as degrees C. The first tiny little increase hump was, I believe, the DNA 200 reading resistance. Then the first two smallish "humps" in the chart are quick clicks to lock, set desired temp, then quick clicks to unlock. DNA 200 is fantastically fast to fire as these were very quick clicks. It started heating a little at each set of 3 quick clicks. Best performance of any mod I've used. DNA 200 set to 100W preheat for 1 sec punch 7, then 75 W max. The huge spike is the first fire on the coil, almost 470 degrees C peak (!). The second nice plateaued line is the second fire, normal temp regulation. The DNA 200 obviously didn't like something about the coil on the first fire. It immediately "settled down" for the second fire. -
Source of between +3.3 or +5V on the board?
Mad Scientist replied to Mad Scientist's topic in Installation and Assembly
John, James, Brandon: Can you steer me to a convenient (hopefully) pad on the board where I can pick up +3.3 or +5V? I need to source about 100 uA continuously and 800 uA peak at anywhere between 3.3 and 5V. I'm assuming that just tapping a battery across the balance connector might screw up the low bat and balance charging. Thank you! -
I had also asked about this. In the mean time, I plan to add a third button the the mod that is "both" -- function is to make the DNA 200 think both buttons are pressed (the buttons both use ground as common so any momentary contact N.O. double pole switch in parallel across the up/down button pads on the board or a single pole switch connected through steering diodes will work fine). It also helps to change the lock sequence to 3 clicks instead of 5. I likewise seem to change temp often enough and I want to be able to do it more easily (like while driving). While we're at it lol, 10 degrees F per click is too much. I'd like to be able to set the increment as a parameter also. And as long as I'm daydreaming on the topic lol, having to hold "both" for 2 seconds is too much. If I press both that means I want the function of pressing both -- do I also have to let it know I really mean it by holding for 2 seconds lol.
The N80 wrap will actually slightly lower the already low TCR of SS for the build as a whole. Can you wrap with SS? -
OK, let's solve the problem step by step. Keep in mind that the board wants to see a minimum level of temp increase as it applies power and the only way it has to detect a temp increase is to calculate it based on resistance increase of the wire applied to the TCR curve so . . . if the TCR doesn't match the wire configuration you're actually using, it won't and can't work properly. It is definitely not the same as prior more primitive TC mod technology that just calculated a target resistance from the TCR and temp setting and didn't care what that is. So exactly what wire are you using in what build configuration? What TCR curve are you using? I'm sure someone here can figure out a workable solution. There are guys here using SS coils successfully and I myself go with Ti / Kanthal claptons without issue, so as long as the build has at least some reasonable resistance sensitivity to temp and is stable, there is a TCR curve that will make it work well. -
connecting PV6 switch to the DNA 200
Mad Scientist replied to Raito's topic in Connectors, Components, and Accessories
Since a 100 ohm resistor was specified if I remember right, I'm guessing closer to 3.3V. That would allow about 15mA forward current through the led, also factoring in the led voltage drop. -
You can let 'er go through 5 or 10 charge/discharge cycles over the next few days to work in the pack and then run battery analyzer and case analyzer. In the mean time, 11.1V x 1.3Ah = 14.43 Wh. You can use 14.43Wh as close enough. The battery is very likely around 1,300mAh real capacity. As far as I know, the only thing the battery setting affects is the battery gauge (although I wonder if it also affects charging). If you still like it after a few days, please let us (and me) know. I suspect everyone not having problems are remaining silent so the only things I've read are problems.
While the battery capacity is getting sorted out, what's the verdict on this thing? I'm thinking about maybe getting one -- the over the top red case is interesting -- but haven't seemed to have heard much from anyone not having some sort of issue with the thing. Is the squeeky wheel getting the grease or is it really a dud? Thanks for insight from anyone who has one.
The small pads are below the fire button. The word "FIRE" is silk screened on the board. The pads for the resistor are to the left, above the "F" in "FIRE" just as the instructions indicate with the pads for the led to the right, just as the instructions indicate. It's hard to describe but if you look carefully at the board right where the word "FIRE" is silk screened, you will see them. -
FWIW, I tend to agree with you. My guess is it is set up the way it is because kanthal users who don't go deep into escribe would have trouble with the device if it didn't automatically sense a coil that doesn't increase resistance much with temp. As a work around for now, set your wattage only about 5 or 10 watts above what the coil can handle non-TC. Then if it jumps out of TC, the max wattage will be limited to an extra hot vape instead of burnt cotton taste. If you want a really exciting vape, see what happens in TC preheat if a wrap shorts and resistance drops during the preheat. Yup, all 200 watts is on tap to get that resistance back up -- blech lol. At the end of the day, it's a sophisticated device and the build does have to be stable for it to work the way it's intended. As a coincidence, not 30 minutes ago I turned a 28 AWG Ti, 34 AWG A1 clapton into 3 sections separated by small gaps of vaporized metal after straightening out a coil I thought was drooping more than I liked. I'll never know exactly what went wrong but obviously the resistance changed as it heated in some unanticipated way and bye-bye coil. In any event, it would be nice to have the option of telling it not to ever automatically switch to non-TC mode. Stop delivering power and flash a message: "Hey, Mad Scientist, your build sucks" or anything lol. -
After the revision of the vtbox200
Mad Scientist replied to MuTong's topic in EScribe, Software and Firmware
I think it is always better to use a wire to connect the 510 shell to the board. Using the mod box itself as a conductor requires a bit more than most DIY builders (and apparently some big mod manufacturers alike) can reliably do. There is a reason why homes with aluminum wiring burned down. Aluminum oxidizes and aluminum oxide is a great insulator. So the takeaway is, use wire to ground the 510. It's only one additional wire and one less issue to have to deal with. -
Temp control not working
Mad Scientist replied to Veles's topic in Manuals, Instructions, and Tutorials
The entry under history looks peculiar. Those are not English characters. -
Hello @Rocky2015, any updates? I've been stalking vaporDNA, VapeNW, VaporBeast, wetvapes, vape95, etc., etc., hoping to see "in stock" appear. No joy lol. Thanks for any info.
Your English is good enough! I understand what you mean. In the General tab, pick a profile and choose Custom for coil material. Toward the right side of the screen under the graph, click Special and enter the wire TCR directly. On the mod, select that profile (power setting locked and double click either up or down then click to the profile number you set) and vape away. If the setting was 105 for the stainless you are using, I think that translates to 0.00105 TCR
