                Posts187
Everything posted by Jentz9517
	Wow it’s been forever since I picked up my Vape but 3.25 and ss316 was killer I tried to litter that around and spread the goodness.. It’s been a long while since dropping in . Is DJaquith still contributing?
	my question is the front/back color ? having a hard time picturing where the (halfs) will meet and if they would look good as solid color or two tone?
	that is some horrible SS316 I used it a few times with Jaquiths UD profiles but it was shuttering terribly as if it had 5times the wattage running through it than was set
	  DNA 200 with SS430 wire questionJentz9517 replied to kentam's topic in EScribe, Software and Firmware received CW ss430 today and wondering why it rides the TEMP SET line perfectly but with anemic vape with TCR 138 ? then use dwcraig recommended 238 which falls short of TEMP SET but gives responsive vape allbeit lacks density and moisture? then play around down the TCR scale to say 200-210 it gets closer to TEMPSET but with about the same Lackluster vape? I guess my main question is why the anemic vape at the wires standard TCR value but shows as its reading the wire correctly to be able to ride the TEMPSET line?
	Yep It wasn't in the least bit impressive. Ya get something besides UD, and use atleast 2.5ID Rod with minimum 5/6 wrap spaced and you should be good if your leads are tight and you have a sound clean atomizer I usually run in the 485-500F range
	I would suspect it seems the two times I bought UD they reacted differently. Both times they seemed to sputter and I had to run at low wattage to quiet it down. I have had great luck with all MKWS wires in 316 316L and also Beadalon which is U.S. Those files I spoke of are pretty versitale or you can use the method vapingbad referred to a few comments up. Stainless 316 is great and then the ss430 which I have only used 28g (nickel free) from Unkamen in U.S. was impressive. Now I'm waiting on the larger gauges from CrazyWire with the higher TCR . Anyhow hope that helps you out
	Go to post #132 the files are there v3.25 andv3.5
	Did you try those csv's I posted up for UD Clapton ? They are earlier on in this thread . UD is probably a wire IMO to stay away from. Jaquith's files that I posted up in previous page will possibly sort it out v1 runs slightly cooler than v2. Also spaced coils with atleast 5 1/2 wrap with 2.5 i.d. Minimum and download the latest service pack on escribe Some have been using SS430 it's available 28g in the U.S. Or from U.K. They have a variety of gauges 20thru31 I have some on its way that has a tcr of 238 which is nice and high compared to the normal 138. But I have had great luck with ss316 also but not UD
	so does anyone know the dimensions on the 250 custom? materials used?
	i get a much better vape with both 3.25 and v3.5 with all brands 316 gb chinese or american excluding the UD which he made for.. the roll I got is horrible. I dont trust that wire
	yes you need to be careful when entering mod res. and always hard reboot after. it should be in the range of 0.003-0.006 my triade is 0.004 also 420F is about 80 degrees too cool for ss316 and with steam engine and even the manual tcr value of 0.0092 you have to set temp at about 520 before you start getting decent puff. if you go here /topic/66739-topic/?do=findComment&comment=900189 I posted two 316 csv's that are good in the 480-520 range
	I am using the csv's that I shared earlier in thread and normally hit temp protection if my set wattage is too high and it has to limit it but vape right around the 485-495 range
	Is that the ss430 or 316 ?
	whats your MOD resistance? its under manufacturer settings
	Must be lots of nickel in that wire
	I got some of each gauge. Is it clean tasting ? I hope because I just missed the 15% off sale
	Dwcraig says use 0.00238 430 normally runs on a tcr of 138 But try 0.00238
	I got some in the cart from CrazyWire different site same wire just debating and thinking about what gauges I want
	Yep got it in the basket 25g. Wonder if I should get thinner also and twist .. Probably so whats this 904 L ? Edit
	im half asleep still its branded Cw ok thanks D.
	Is this wire worth buying? do you like it better than unkamen?
	It's 0.00138 Edit holy Frick 238 ?
	Thanks a lot Bill yep mine was at 0.004 then thought I would see if new firmware would mess with it and appears it did change atleast on my others, I wasn't able to re-test triade just a big question mark in atty analyzer ?
	having issues with escribe completely getting deleted from computer after countless installs windows 7? just dissapears no recycle bin ? notta! another seperate home desktop win dows 7 threw everything in the recycle bin? what is a service pack? my MOD resistance is reading higher now with new "service pack? 1 mod my triade will not read at all with dead short but reads atty? this is beginning to be too much and no instructions.. can someone help me out P.S. can someone give me the case analyzer results for triade? it erased mine ? didnt ask or anything..
