copyman
Everything posted by copyman
  1. Hi, I tried with several types of batteries 21700/18650, all new. With the change of the firmware there is no change. I tried with several types of batteries 21700/18650, all new. With the change of the firmware there is no change. Nowhere does it say what type of fast charging is used - QC or PD...
  2. Hello, I have certain problems with charging the DNA100C. The maximum current is 1.5A. I tried all kinds of chargers that support fast charging 5/9/12V, but it has no effect. The limit in Escribe is at the maximum - 3A. According to the description, the charging of 5B is 2A, fast charging 3A is also supported. Does anyone have any idea what's going on? Thanks
  3. Version 1.0.0
    819 downloads
    The theme is based on my previous topics. It works on DNA75C DNA250C, and in DNA75C does not operate "Power bank" mode. The theme of VapingBad is the basis theme - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution. Copy from VapingBad ***************************************************************** In the photos the 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status: default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field: atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage ***************************************************************** Extras: In Lock Screen down: Current in charge or root temperature in non charging mode. In Main Screen two resistans: locked ohms and life ohms. In Main Screen right to Power: temperature of board or output voltage in VW mode. In Main Screen right to Temperature: Temperature ot last puff
  4. Hello, Under Mac OS 10.13.6 SP19 does not work! It starts normally but when I plug in a device and it crashes. For the past year there is no solution to the issue!
  5. Hello, EScribe2_SP20_INT.pkg cannot download it! Under Mac OS 10.13.6 SP19 does not work! It starts normally but when I plug in a device and it crashes. Where can I get SP20 from?
  6. Hello, The theme is very heavy because of the pictures. The memory is used almost completely. You can free memory space on your mod by deleting some of the materials that do not use. You probably inserted some extra material into Rebel - this is the difference between your two mods ... Best Regards Milen Cholashki
  7. Translation of the latest Escribe - 2.0 SP17 INTL for Mac OSX (I hope there will be no problems under Windows) Download Translation: bg.po.zip
  8. Version 1.0.5
    5,030 downloads
    The theme is based on my previous topics. It works on DNA75C DNA250C, and in DNA75C does not operate "Power bank" mode. The theme of VapingBad is the basis theme - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution. Copy from VapingBad ***************************************************************** In the photos the 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status: default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field: atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage ***************************************************************** Extras: In Lock Screen down: Current in charge or root temperature in non charging mode. In Main Screen two resistans: locked ohms and life ohms. In Main Screen right to Power: temperature of board or output voltage in VW mode. In Main Screen right to Temperature: Temperature ot last puff Screenshot for Simple version: Screenshot for extended version: Copyman-Gothic-III.ecigtheme Copyman-Gothic-IV.ecigtheme Copyman-Gothic-IV-simple.ecigtheme
  9. Version 2.0.1
    862 downloads
    This is a template for DNA75C and DNA250C! Replay menus. The memory is filled to the limit. Sorry if something is abbreviated or omitted, but there is no memory - all squeezed up .. 99.5% is the memory limit, and 0.1% more is not upload to board. The theme of VapingBad is the basis theme - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution. Copy from VapingBad ***************************************************************** In the photos the 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status: default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field: atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage ***************************************************************** Extras: In Lock Screen down: Current in charge or root temperature in non charging mode. In Main Screen two resistans: locked ohms and life ohms. In Main Screen right to Power: temperature of board or output voltage in VW mode. In Main Screen right to Temperature: Temperature ot last puff
  10. Version 2.0.1
    740 downloads
    This is a template only for DNA250C! Will not work on DNA75C! - there is not enough internal memory. Replay and Power bank menus. The theme of VapingBad is the basis theme - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution. Copy from VapingBad ***************************************************************** In the photos the 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status: default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field: atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage ***************************************************************** Extras: In Lock Screen down: Current in charge or root temperature in non charging mode. In Main Screen two resistans: locked ohms and life ohms. In Main Screen right to Power: temperature of board or output voltage in VW mode. In Main Screen right to Temperature: Temperature ot last puff Power Bank work on DNA250C video - sorry, but it's only in Bulgarian. Max output current - 1,9 Amps. It is mandatory to use the USB OTG cable!! New version ... Copyman-DNA250C-Circle.ecigtheme Copyman-DNA250C-Circle2.ecigtheme Copyman-DNA250C-Cloud.ecigtheme
  11. Translation of the latest Escribe - 2.0 SP13 INTL for Mac OSX (I hope there will be no problems under Windows) Download Translation: bg.po.zip
  12. Chief Brandon said: Christmas
  13. Waiting, waiting
  14. Of course this is a solution, but I personally happen to me when I get the device to accidentally push the buttons. It is likely that removing this feature is related to the fact that unlocking can now be with custom buttons. Anyway - this feature I miss - I've always used it!
  15. Interestingly, this feature does not interfere with anything but is useful for those who carry the devices in their pockets. Software can solve the problem very easily ..
  16. Hi, I have not found any information on how to lock the three buttons. I tried the way of the old DNA , but here pressing both the UP / DOWN buttons does not work.
  17. It's not true - I was now trying SP23 with 500 mA, 1A and 2A - in all modes it charge normally
  18. Version 1.0.0
    309 downloads
    The theme of VapingBad is the basis theme - here are changed icons and there are extra features .. Copy from VapingBad ***************************************************************** In the photos the 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status: default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field: atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage ***************************************************************** Extras: In Lock Screen down: Current in charge or root temperature in non charging mode. In Main Screen two resistans: locked ohms and life ohms. In Main Screen right to Power: temperature of board or output voltage in VW mode. In Main Screen right to Temperature: Temperature ot last puff
  19. Version 1.0.0
    441 downloads
    Griffin 22 mm by GeekVape evaporator profile - Notch coil SS316L evaporator profile. Here are all the files: logo .. etc. 2 x Notch coil 5 mm 0,2 Ohm iInner diameter: 4,8 mm. Total Ohm: 0,1. Power 35W / 45W preheat, Material profile: custom SS316. I've used 2x 5 mm Notch coils but slightly flattened, If you own a 25mm version of Griffin you will not have this problem. Power may be up - this is the initial experiment, here temteraturata is far from the setpoint. Here is my review, which is unfortunately not in English: DNA200-SS_316L-SM.csv
  20. Version 1.0.0
    290 downloads
    Griffin 22 mm by GeekVape evaporator profile. One experiment - 6 months of use. Here are all the files: logo, profile of the material, etc. 2х Ni200 hard 0,35 mm core + Ni200 0,2 , iInner diameter: 3 mm, 7 wraps, Total Ohm: 0,04. Power 60W / 70W preheat, Coton "Bacon" Material profile: custom Ni200. The Clapton coil should be carefully burned with a small burner. Good burning is the key to success! Here is my review, which is unfortunately not in English: Clapton-log.csv.zip DNA200-Nickel_Ni200_(linear_TCR)-My.csv.zip
  21. Version 1.0.0
    601 downloads
    Aromamizer Plus by Steam Crave evaporator profile. Here are all the files: logo .. etc. 2 x Ni200 hard 0,5 mm iInner diameter: 3,5 mm, 7 wraps, Leg length 6 mm. Total Ohm: 0,031. Power 100W / 120W preheat, Coton "Bacon" Recommended 3 mg nicotine !! Material profile: original DNA Ni200.
  22. Version 1.0.0
    239 downloads
    Doggy Style by Anymodz evaporator profile. Here are all the files: logo, profile of the material, etc. Ni200 hard 0,35 mm iInner diameter: 2,5 mm, 7 wraps, Total Ohm: 0,078. Power 25W / 30W preheat, Coton "Bacon" Material profile: custom Ni200. Animodz-Doggy-Style1.png.zip Animodz-Doggy-Style2.png.zip Doggy-Style-Ni200.ecigprofile.zip Ni200_(customTCR)-My.csv.zip
  23. In Escrebe 2 V 3.1 no change ....
