Everything posted by copyman
Version 1.6
490 downloads
Information: The theme is based on my previous themes. It works on DNA75C, DNA100C, DNA250C, and in DNA75C/DNA100C does not operate "Power bank" mode. Supports replay. Supports the new Season Mode feature - Works only with Escribe SP45 and firmware 1.1 SP 55.1 On the idea of vapingbad - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution. Preheat: ***************************************************************** Preheating has several states: 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status: default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field: atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage ***************************************************************** Extras: In Lock Screen down: Current in charge or root temperature in non charging mode. When using a power bank, an icon is displayed. In Main Screen two resistans: locked ohms and life ohms. In Main Screen right to Power: temperature of board or output voltage in VW mode. In Main Screen right to Temperature: Temperature ot last puff In Main Screen top: The name of the profile below is the material used In Battery Screen: Below is shown what current is the charge, and the displayed power indicates whether the fast charge is on: normal charge - 7.1 watts / fast charge - 13.2 watts (approximate values) New: Added on/off of Session Mode on the main screen and timer setting in profile and settings Review with presentation of the work of the feature - has subtitles: Smoking Maniac Youtube chanel Hadron-V1.6-sesion.ecigtheme -
Thanks James, this version is now working ot Windows, thanks for the quick response! However, I have the following problem with the Mac OS version: Since version 30.3, none, including this one, start. No error appears on the screen. Mac OS 13.6 - probably with an older version of Mac, but I can't update it. In the system logs I find the following (attached file) Is there any help for old systems? bug2.txt
Thanks James, this version is now working on Windows, however, I have the following problem with the Mac OS version: Since version 30.3, none, including this one, start. No error appears on the screen. Mac OS 13.6 - probably with an older version of Mac, but I can't update it. In the system logs I find the following (attached file). Can you help? I work primarily on Mac... bug2.txt
Hyperion Remix for DNA Colour Mods
copyman reviewed Serenity E's file in DNA 75 Color, 100 Color, 250 Color
- 4 comments
- replay
- power bank
(and 1 more)
Tagged with:
Version 1.5.0
296 downloads
Information: The theme is based on my previous themes. It works on DNA75C, DNA100C, DNA250C, and in DNA75C/DNA100C does not operate "Power bank" mode. Supports replay. On the idea of vapingbad - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution. Preheat: ***************************************************************** Preheating has several states: 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status: default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field: atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage ***************************************************************** Extras: There are two main screens - extended and easy! In Lock Screen down: Current in charge or root temperature in non charging mode. When using a power bank, an icon is displayed. In Main Screen two resistans: locked ohms and life ohms. In Main Screen right to Power: temperature of board or output voltage in VW mode. In Main Screen right to Temperature: Temperature ot last puff In Main Screen top: The name of the profile below is the material used In Battery Screen: Below is shown what current is the charge, and the displayed power indicates whether the fast charge is on: normal charge - 7.1 watts / fast charge - 13.2 watts (approximate values) Main screen's: Extended 1 Extended 2 Extended 1 Extended 2 Extended 3 *** Only the Centaurus theme has a reworked battery display for now: Easy main screen: Centaurus Hyperion- 4 comments
- replay
- power bank
(and 1 more)
Tagged with:
Works on Mac OS X 10.13.6 High Sierra /DNA100C/DNA XXXX Thanks!
Install ot Mac OS X - Another way to get to the folder if you did not enable the view of hidden system folders:Enter the EScribe menu: Help-> About, press 7 times on the logo Evolve and then enter the menu Option -> Langauge -> Edit like this you open the folder with the translations. Add/replace .po file.
Lost Vape Hyperion DNA 100C connect for Macintosh
copyman replied to Higgins's topic in EScribe, Software and Firmware
Patience, you're not the only one waiting for the Mac OS version 😉. I use a virtual machine to work with version SP27. -
I have the same question!
Version 1.4
646 downloads
The theme is based on my previous topics. It works on DNA75C DNA250C, and in DNA75C/DNA100C does not operate "Power bank" mode. The theme of VapingBad is the basis theme - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution. Copy from VapingBad ***************************************************************** In the photos the 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status: default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field: atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage ***************************************************************** Extras: In Lock Screen down: Current in charge or root temperature in non charging mode. When using a power bank, an icon is displayed. In Main Screen two resistans: locked ohms and life ohms. In Main Screen right to Power: temperature of board or output voltage in VW mode. In Main Screen right to Temperature: Temperature ot last puff In Battery Screen: Below is shown what current is the charge, and the displayed power indicates whether the fast charge is on: normal charge - 7.1 watts / fast charge - 13.2 watts New in Version 1.4 - Redesigned battery indication. For example: -
You are absolutely right, I just did not pay attention to what you wrote, focused on my problem that the current can not rise above 1.5A 😇
Problem found its solution. Charging with 3A requires a USB-C power adapter according to the PD standard and USB-C to USB-C cable. To clarify - not some adapter with USB-C, but just one that supports the full PPC protocol. The maximum current in this case for me became 2.72A. I'm also waiting for a MacBook Air adapter to check if the current can really go up to 3A. It is amazing to me that there is no information about charging the DNA100C anywhere - even here. In my opinion, to produce something so good and not explain elementary things is simply unforgivable! I had to buy several different adapters to do tests and figure out what I could just read. It doesn't matter - I hope what is written here will help the next ones 🙂
Thank you for the information! Strange, very strange and the cable in the mod set is USB-A to USB-C. One adapter I have supports the power supply of Mac Book, but the current is still 1.5A. The power supplies for MacBook are according to the PD standard. Not to mention that there is no PDF for this board. Now I will try another adapter with USB-C ... Thank you again!
Thanks Wayneo, but i tested charging with a USB-C adapter (the adapter is 3A) and a USB-C / USB-C cable and there is no change in current. Now I fully discharge a battery to see if the current will not rise. Usually the adapters with USB-C are type PD, I do not have one with USB-C type QC, if that matters. What model of adapter do you use?
Yes at least 5 types of cables - no change - always charge with 1.42 - 1.48A. Several types of power adapters giving current of 3A, type QC and PD - no change
Here it is different, fast charging supports voltage increase, but for this purpose on the data buses information is exchanged between the charging adapter and the device about what supports both. Thus, if there is support for fast charging according to PD (power delivery) or QC (quick charge) protocol, the supply voltage is switched to more than 5V.
