            Asfanews
                Posts31
                Days Won2
Everything posted by Asfanews
	Hi guys, I am thinking of a new mod, with DNA60. I can't find the screen file for FreeCAD, and I cannot bend the flat wire. I need something like that
	hi everyone, i can't find just the stl with the screen. I need it to do a simple screen Holder. Can anyone help me please?
	send an email to the evolv, this is what they told me to buy one
	I'd like to make a bf mod with dna-go, but first I want to be sure that: Can I use 18500? Can I vape at , for example, 13Watts without thee drop I get when I use mood with mosfet?
	no man, there could be many options to fix my issue, but it was the connection as previously suggested. I checked the box, and the output pin needs to be tightened
	I got the TCR from the crazywire datasheet The table and the other data weren't available, I also wrote them asking for it, but no replay. So I couldn't create a new material with Steam-Engine. The only thing I could, and I did, was to create a new material with escribe, just from the TCR. If need anything else, I am here
	NiFe48, 26AWG, 5 or 5 wraps, from CrazyWire
	First, Thank you for your help. Second, you're saying that the drops of power in the following pic is due to poor connetion? (no hot spot I am sure, it's just a 5 wrap 26AAWG coil). I'll check tomorrow and update the post.
	yes, it's just to explain the lack of power I am having and that I don't understand why. By the way I did the test on the two mods at the same temperature and it was the same.
	this pic is from another bf, a simple dna75. Here the power released reaches the right spot and the atom keeps vaping I don't know why, in the first case (DNA75C) the power drops so I can't vape!
	Hi folks, I am going crazy. I am using my bf in T.C. but even from the first puffs, when the atomizer is still cold the power drops immediately and it doesn't vaporize, just a little. The first pic is from the DNA75C, the light green line shows a peek at the beginning but then suddenly drops.
	I had the same problem, I changed the display and it has worked fine. unfortunately today it stared again with the same issue. The box works, it fire and goes up and down, but the screen started to display numbers like yours and then black. Is it something with the board or am I doing something wrong?
	Did you do that? I am still looking for the same.
	I don't know how but I found that the little metal clamp which keeps the rubber that push on the down button on bord has fallen somewhere and got lost. I don't know how to replace this little peace to keep the rubber part of the button on the contact. Any Idea of where I can find the little clamp or something similar? P.S. I found the rubber part in the circuit, but the metal got lost
	Hi guys, My Epetite dna60 still fires, but the display happens to be broken (I hope so). I was wondering if has appen to anyone before and if you think I can just buy the display and make it work again. In case, which display do I have to buy? The small or the big one? Is the same display used for dna75? Thanks a lot
	I do the same, but since it's a Rigid Copper Wire I think I can go with the 20 AWG, but I am not sure
	Can I wire a DNA75 with Rigid Copper Wire 20AWG? I mean all the connections
	Can I just solder the GND to the chopper blade (red line) and be fine? Then B+ to the battery (+ of course) and the OUT to the positive pin of the atom. Am I doing something wrong, because I think it doesn't detect the atom because of this.
	  3 wires wiring, Can I solder the negative here?Asfanews posted a topic in Installation and Assembly Can I solder the negative coming out from the circuit where I draw the red line and be fine? I ask because I previously had some problem with this wiring, but I don't know if it was this or not.
	Is that possible? I have a DNA75 which I am about to wire into a delrin box. I also have some copper blades (0.5 mm thick). Can I sub the wires with the blades without any cons? I thought about something like in the pic below:
	  DNA25D Step file neededAsfanews replied to Asfanews's topic in Manuals, Instructions, and Tutorials thanks for the info, I hope they have the same layout. I converted in .step file a DNA40 .stl file I found somewhere in internet. I attached the file for the people that might have the same issue. DNA40.FCStd
	Hi everyone, I have a DNA25D left and I am designing a small box. I can't find the .step file which are the only kind of file my FreeCad for mac can open and let me work on.
	Thanks a lot man. I didn't know it was so easy and that it was made to snap off soo easly. Thanks also for the cleanng up the edges tip, I didn't know I could do. Now It fits perfectly in the slot it was designed for.
	I've just recived the DNA60, and I am assembling my first box bf. I didn't expect I had to cut the circuit. Any suggestion please on how to do it? I have to cut the two lateral bars to make the circuit fit in the slot in the box
