dwcraig1
Everything posted by dwcraig1
  1. Vapecige BTBox200 thermal settings. Results from me running case analyzer
  2. If I had this problem I would start off putting a short piece of copper wire shorting the posts of a dripper atty and check just what figures I got with atomizer analyzer. If there is too high resistance between the 510 and atty caused by a bad connection between the two 510 pins the result will be as described.
  3. Thermal results for my Hotcig DX200 This is what I got, it sure looks unusual though compared to others.
  4. Well I guess I need to learn how to read, the mod's screen said "OHMS TOO HIGH" not "LOW".... DUH (tungsten no doubt)
  5. "Low Ohms" would come on the screen of the mod periodically so I stopped it, will try again with two lamps in series. My cold ohms was 0.5 and I had to turn off TP as it went to immediate TP when firing.
  6. What does the board do with the settings of case analyzer, is it for TC accuracy?
  7. Well folks, the above setup failed due to " LOW OHMS", I'll run the battery down vaping it tonight as I want to run the case analyzer. I understand that 1 ohm is recommended.
  8. Here's my setup, a 12 volt 35 watt quartz bulb. About 0.5 ohm cold. I haven't done it yet but this is what I probably will use. There is quite a bit of heat so care must be taken, at least the heat it away from the mod.
  9. That's also the brand of the battery inside. So I thought I'd give the Hot Fire charger a try. I've read that it may over charge. Finished at 12.71 volt according to my meter. About 4.24 per cell I guess, not the best, could have been worse.
  10. I just about replaced it just to get it off my mind but it really works OK so I'm leaving it be for now.
  11. I would rather used a 7 x .50 mm bolt but I only have the tap. Screw nut onto the tap as shown, then washer, then receiver and screw into 510. Hold tap from turning and screw nut downward drawing 510 into nylon sleeve. My nut here is a VS rDNA 510 with it's one end drilled out. Crude but effective.
  12. Re 510: I measured the voltage between the battery negative and base of atty (0.35?) while firing and got 0.14 volts on my Hotcig and 0.03 volts on my Opus. I made up a little puller to pull the pressed in one out to replace with a FD v3 shorty. The hold back for me is possible need of warranty and it works just fine.
  13. Gee, folks complaining about not being 1800 mah, I'm more worried it's not 35C.
  14. As I don't have mine as yet I was going by the dimensions listed for the Lion Power 1500 35c. DNA200 works fine with 7.4 volt pack but only outputs 133 watts. [/QUOTE]
  15. As I don't have mine as yet I was going by the dimensions listed for the Lion Power 1500 35c. DNA200 works fine with 7.4 volt pack but only put out 133 watts.
  16. My plan for my Vapecige box was to convert it to dual 18650's but it appears that it may be about 5 mm too short lengthwise for a sled. Perhaps someone would be so kind to measure the area for the battery and post it. A couple good 18650's could provide 22 wh.
  17. In EScribe using the "Mod" tab, charging mode. If set to "maximum puffs" it will charge to 4.2 volts per cell and if set to "maximum recharges" it will charge to 4.1 volts per cell.
  18. A bad connection with the atty at the 510 whether it be the ground or the output would have the same result, check that center pin to atty connection as well.
  19. Keep in mind than if the DNA board sees a data path present it will only charge up to 0.5 even with USB 3.0
  20. Yes, it still does with newest version and firmware.
  21. Either the insulator on my Opus' 510 wasn't screwed in all the way or I forced it down with my Infinite Magma clone with it's extra long 510. I was having problems with changing resistance till I correcting it. Here's a picture of it prior to screwing it all the way back in. I then added a dab of Super Glue gel to keep it there. It didn't appear stripped so I'm not sure how it got that way. BTW, that glob of sealant you see here appears to be silicone that "they" used.
  22. I'm really hoping someone "in the know" addresses the 3.6 volt cut off stated here.
  23. /topic/65591-topic/?do=findComment&comment=885508
  24. While you may already have this version it would maybe be a good place to start. 2015-08-17 EScribe (I'm slow)
