James
Everything posted by James
  1. James
    Translations
    If anyone is interested in helping translate EScribe into their native language, I've posted a Github: https://github.com/Evolvapor/EScribeTranslations You can edit these and send pull requests for changes. (Or use a software like TortoiseGit, or e-mail.) It being on Github should make it easier to make corrections etc. hopefully. (Does anyone know if there is a better service for this for translations?) Thank you!
  2. Most of the benefit of logging in is for manufacturers. Production Utility (in Tools) requires being logged in. Production Utility does link the serial number to a manufacturer, so that when you click Get Information, it will say the name they entered for their account as who it was produced by. On request, we can also mark an account's manufacturer profile as 'confirmed'. Doing this makes it say "Confirmed" in Get Information, which serves as a bit of a 'genuine check' for the mod, instead of just for the board. I'd add some user benefits to logging in if I could think of any to offer.
  3. mikepetro: Hmm. We could do that. What kind of banner are you talking about? A generated image with statistics on it, or...?
  4. lsusb just gets a maintained list of VIDs and PIDs. It doesn't query the device. Whether it shows or not isn't related to whether USB is working. 268b:0405 is the DNA 200, yes.
  5. pdizzle, are you running the 2015-08-07 firmware?
  6. Posted the 2015-08-17 EScribe. Same firmware as 2015-08-07, adds the option of installing ECigStats.
  7. D022A, what version of firmware were you running at the time? What mod is this? Could you PM me the serial number? Thanks! Help Desk should be able to look at your board and replace it.
  8. Has cell 1 ever read properly? If not, how did the mod pass through Production Utility? (Did the mod maker not use it?)
  9. Once you hit the Fire button, does it stay on? That'd narrow it down between a USB Voltage reading issue and a sleep pin related issue.
  10. The newer versions of EScribe (in the Early Firmware thread) save where the program was when you last closed it. If this is not working, hmm. Do you have a multimonitor setup? Running in Extra Large Fonts by any chance? The fire button should not cause reboots. If you're able to fire at a reasonable wattage though the power connector has to be fine...
  11. How do you know pressing the fire button reboots the device specifically? What behavior are you seeing? Does something display on the device screen? If you see anything on screen, that rules out it being a firmware issue. If Device Monitor works then your firmware is working. What are you seeing for battery voltage? I wonder if something is wrong with your battery connector. When you use Device Monitor, are you able to fire? Or does it say CHECK ATOMIZER? (What are the battery voltages reading? Keep in mind, battery voltage is read over the balancer taps, whereas power actually comes from the main connector (JST in the Hana's case).)
  12. Google for LiPo discharge curves, or the discharge curve for your particular battery to see what will happen. You will see that capacity does not advance much at all once you are in the 3V range - at that point a LiPo battery is essentially drained. Weak Battery will move horizontally along that curve to lower C levels until it finds what the battery can sustain at its current state of charge, allowing you to use all the capacity available at lower C levels. You can see on these curves that the 10C line will end at a lower capacity than 5C, which ends at a lower level than 1C, etc. When the battery is really low, it simply can't do 50W, and a few puffs later, can't do 40, 30, etc. But we have it give you what the battery can stably give. Letting the battery fall even further before reducing the current demanded of it won't help. Without the Weak Battery feature (it's not just a warning message), you see the capacity falls off a cliff on those discharge curves? You'd be done already. Unless your battery connections have a ton of resistance, lowering it is unlikely to buy you more than a percent or two.
  13. Hello promod2000avenger, What do you mean by XP 'flashes between black and normal screen'? This sounds like a bug we ought to fix. Could you describe the behavior (or post a video)? Thanks, James
  14. combatwombat: Ideally, using the battery analyzer with a sufficiently sized resistor block for an atomizer. If your battery is a standard 3S LiPo, the curve won't change substantially. That'll just tell you what the actual battery life is. If it jumps around substantially, chances are your battery has very different voltage from the stock settings (less likely) or the wrong capacity set (more likely. Also, once you change the watt-hours setting, it's good to let the battery fully charge so that it has the correct starting point. What battery are you using and what watt-hours do you have, out of curiosity?
  15. If you use EScribe's Soft Reboot, it will save settings. Hard Reboot or cutting power will not.
  16. Posted up 08/07/2015. Custom splash screen times, and some improvements to the 2-cell support. Have a good weekend, James
  17. XP should work, as long as you have Service Pack 3 installed. Do you have any software that hooks into the operating system (say, antivirus) that is rarer?
  18. ndb: Yes, the atomizer resistance should not be included in the mod resistance. If it's the only atomizer you use, it doesn't really hurt, but that's a big if... As far as mod resistance goes, honestly it's much better to leave it at zero than to be guessing. A value higher than what is right can destabilize the temperature protection, especially at low power when it's most useful (the dry case).
  19. Hello sammao, What are you clicking that gives that error? Thanks James
  20. VapingBad: What do you mean by while the device was connected? Normally it's connected when it suggests updating firmware. Or have you found that affects its success?
  21. Battery Analyzer considers the pack 'empty' when it can no longer sustain 5 watts. Due to the Weak Battery feature, the DNA will "walk horizontally" to lower C levels on a traditional battery discharge curve when the battery is getting low (hits the soft cutoff voltage). The battery would have been finished had it kept demanding the same power level. By doing this we extract basically all the useful life the battery has to give. So the difference due to chosen power level will be mostly losses due to internal resistance in the battery (and some heat dissipation in the fuse). I wouldn't sweat a 10 or 20 watt difference in the power level you choose for Battery Analyzer.
  22. Good find. Fixed. I updated the 2015-08-05 download.
  23. Thanks speed4mee. That is a good find. I've rebuilt it and no longer get that error. So there's a newer version up. Also made Device Monitor remember the time scale while I was at it.
  24. For those it is not working for, are you on 32 or 64 bit Windows 10?
  25. Laguz, yes, if you don't want to use Battery Analyzer you can put in a curve manually. The only difference is that EScribe wants the curve in percent remaining, not mAh. (It splits out Watt-hours as a separate setting.) I think you will find Battery Analyzer produces a similar result, though.
