Notes:
  • You can press the fire button to exit out of a screen that doesn't have a back button.
  • LED colors styled to the theme.
  • When you change the material of a profile (eg. from Watts to SS316L) you won't have the appropriate toggles (eg. Temp Control, Replay)  activated right away. You need to back out of the Atomizer Profile screen, fire the mod and go back into the Atomizer Profile screen. This is an Evolv/Theme Designer issue.
  • If you have temp control enabled, you can switch positions of the power and temperature field on the main screen by enabling "Big Temp" in Menu -> Settings
  • In the Atomizer Profile screen you can adjust the Pre-heat temperature either via a Punch gauge or via a Temperature field. You can switch between them with the new toggle next to the Pre-heat label.
I made this version with the new DNA250c Paranormals in mind. I think it would look good on the darker ones especially. I'd love to see some handchecks if you're using it on a Paranormal!
  • Like 4
  • Thanks 3
omghax
This is now my new default, from Material Dark. I was going to try and make my own but what's the point now! Thank you so much ❤️
Mr.Ninno
   0 of 2 members found this review helpful 0 / 2 members
This is missing some functions But It is Not bad.
I'm happy to take requests. What would you like to see added?
monstis
Rocked this theme as soon as I first plugged my Paranormal in. Love it! So very functional. Suits my style of use perfectly.
I have tried others since but kept going back to it.  I have made some changes to the charging, main page and  coil change page.... nothing else.
The changes weren't needed as it was  perfect for me  to begin with. I just like to customize is all.
Keep it up!
puma303
I find this really interesting theme. However, I would like to ask if in temperature control it was possible to display the coil temperature and the watts used in this mode.
Kirah
Looks fantastic its my favorite theme by far only thing i would like more is a black / gray scale version of it
Aether
I like it! I'd definitely like more recolors available! But the template is super clean.
I just tweaked it a little to try and match, thanks for the hard work!
https://imgur.com/a/rlsEBTi
verry nice theme keep the good work thanks
                                               gr rob.
Yorkyboy
Great theme.  Very clear and some great design features.  Thanks for sharing your hard work :)
  • Thanks 2
Vapin
Love it Tim, you have another winner, thanks for the work and taking the time to create great themes. :thumb:
