This is a premium enhanced theme for Evolv DNA Color devices, engineered to unlock the platform’s full potential without sacrificing elegance or clarity.
Every element has been refined with precision. The interface is exceptionally clean, highly functional, and intuitively structured for serious users who expect total control without visual clutter. Dozens of existing themes were analyzed, their strengths distilled, and their weaknesses eliminated to create a superior experience.
Beneath the minimalist design lies deep capability: extensive hidden fields and advanced controls are seamlessly integrated for those who demand more.
Optimized for minimal Off-Board and On-Board memory usage.
Full control over: Temperature & Wattage (quick access), Replay, Preheat, Boost, SESSION Mode (Auto Fire)
No wasted space. No unnecessary noise.
Just performance, precision, and complete command.
Pro.Vapers_Manual_EN.pdf
https://youtu.be/aEq-EMRAgBU
Theme Full Info:
Quote
Auto Fire (Session Mode):
Daylight Mode:
Action Center :
Iconic Menus :
Locked Screen:
Main Screen:
System Menu:
Display setting Screen:
USB INFO Screen:
Lock Screen (lock settings):
PowerBank Screen:
Battery Info Screen:
Last Puff Screen:
Live Puff Screen:
Device Info Screen:
Custom Recording Screen:
New Atomizer Screen:
User Toggles Screen:
Diagnostics Screen:
Battery Optimization:
Used Abbreviations:
PWR: Power Mode
TCM: Temperature Control Mode
TC: Temperature Control
Pheat: Preheat
Curnt: Current
Temp: Temperature
ATTY: atomizer
Nrg: Energy
Puff T: Puff Temperature
Batt: Battery
Batts: Battery Pack
Flip Scr: Flip Screen
PWRBank: PowerBank
Cold T: Coil Cold Temperature
Peak: Peak Temperature
Ω Low: Ohm Too Low
Ω High: Ohm Too High
Overheat!: Too Hot
Fire from screens:
Quote
3.
8. Save and Apply changes
Logo1.zipLogo2.zipBrands.zip
a25.gif.9d2953b48bbde38fa695df99ba027d2e.gifIn all versions you can modify screens and access to text icon library. To use icon library, you can choose/select the icon textually on any page or anywhere in the theme.
Versions Info: (SCREENSHOTS)
Quote
The features and menus of all versions are the same, but they are completely different in appearance.
Special Thanks To:
Quote
 Description for Translate.txt
Hope everyone enjoys!
Edited by aMirS
What's New in Version 11.0 + GOLD & GLC   See changelog
  • Updated to  latest firmware (SP44)
  • New feature called Auto Fire (A.Fire) in profile setting screen. When A.Fire enabled, you don't have to hold the Fire button down. Instead, you press it to start firing, and press it again to stop firing. This is useful at low power settings (or with a temperature-sensing coil), especially with high thermal mass coils or e-liquids that need to warm slowly.
  • Led version highlighted color changed.
  • A new variant called the GLC version is available for download (limited time) as a thank you to those who posted reviews or shared mod photos in the comments.
  • Now the Gold version is available for download.
  • Daylight Mode added to Portrait, SG, LED, Army and YL variants: Sometimes you may be exposed to strong sunlight. Daylight helps you to easily see and read the screen clearly even with sunglasses. Daylight mode is activated by pressing the radiance icon on the bottom of main screen.
  • And added more small and smart features...
What's New History
Quote
  • Gview Screen guages Updated.
  • Profile screen updated and merged to a screen.
  • customization resources in theme description Updated. (More than 200 logo Includes: Boxer, Centaurus, DeadRabbit, Dovpo, Drone, Evolv, Geekvape, HCigar, Hyperion, Lostvape, Mirage, Odin, Paranormal, Rebel, Steam Crave, Thelema, Therion, Thinkvape, Triade, VandyVape, Vapecige, VapersCloud, VaporGiant, Viciousant, Football league teams logo, Marvel characters, Cartoon logos, Girly logos and wallpapers, Skull logos, Cars Companies logos, Mario, Sonic, IOS, Android  and ...) Read customization and resources info in theme description for more info and help.
  • Reduced used spaces.
  • GMatrix version temporary removed.
  • Designer Edition moved to customization resources in theme description.
  • New Screen called the Gview has been added and replaced with chart icon in main screen : A screen for displaying vaping information includes charts and gauges.
  • Indicator light colors updated.
  • Small change in profile screen. (Temp Field)
  • Silver variant removed from download box and available on request for private use. (comments).
  • Landscape version temporary removed and It will be available with a new and different appearance in the next update.
  • Direct link created for gold version update .
  • A new variant called the YL version has been added in download box.
  • Some change in portrait version.
  • Fixed LED version reported bug.
  • Adding a new feature called Action Center in all variants.
  • Reduced used space.
  • Fixed Army.D version TC mode.
  • A new variant called the ARMY.D version has been added in download box.
  • Update customization resources in theme description.
  • Fixed SG variant in 75c mods. now it's available again in all DNA Color mods.
  • Modified portrait version background.
  • Added some smart notifications and warnings (all versions).
  • Added back button in all fireable screens (all versions).
  • Added lock shortcut in LED version main screen.
  • Added firing view in LED version main screen.
  • Updated icon and logo library(all versions).
  • Added customization info & resources  in theme description. (Includes: 30 custom background, 69 custom logos, 200 icons and mod logos)
  • New Silver Beta Version
  • Modifying Action Center in all variants: Some custom themes have serious bugs in the  REPLAY / TC / BOOST implementation. The result is a frustrating disappointment with the promised possibilities of the DNA chipset and the user wonders what he has spent so much money on. "Action Center" screen help you to find and fix incorrect settings or settings not intended by Evolv in each profile. This allows you to rule out incorrect settings of the mod. "Action Center" screen tried to identify problems and at any time it is possible to correct them without the need for a pc or spent more time.
  • In normal mode and when there is no error or incorrect setting, "Action Center" is not displayed, but when an error is detected, this feature is displayed as an icon on the home screen, lock screen and diagnostics screen.
EScribe Suite 2.0 SP44 (latest firmware) :
For US-based customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP44_US_ServicePack.exe
For international customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP44_INT_ServicePack.exe
For customers using Linux, see the beta thread.
  • With version 11.0 + GOLD & GLC:
  • Download
  • Like 11
  • Thanks 7
Atlantis
Thanks!
ZumaFx
Kenz0r
Thanks for the amazing work!
JD210991
SIR COILS
· Edited by Sir Coils
Suthiwas
· Edited by Suthiwas
Sflow
Papaws Vape
THANKS AND WELCOME BACK
Jeff_Jeferson
· Edited by Jeff_Jeferson
Perfektní! Pěkná práce.
Mark R
JBoogie
mahmoud
mykl10
LordPuffington
Excellent work.
Very impressed so far.
JOE VAPER
ZebOctets
Is this normal?
mactavish
HaCkStAr
eVape
JPinho
Pcruz
Keep it going.
onnyteam
· Edited by onnyteam
*You are the BEST!!! 🥰
Thelema DNA250C
WLM88
· Edited by WLM88
KRYSS
All the best.🌹
Beefstu2000
