This is a premium enhanced theme for Evolv DNA Color devices, engineered to unlock the platform’s full potential without sacrificing elegance or clarity.
Every element has been refined with precision. The interface is exceptionally clean, highly functional, and intuitively structured for serious users who expect total control without visual clutter. Dozens of existing themes were analyzed, their strengths distilled, and their weaknesses eliminated to create a superior experience.
Beneath the minimalist design lies deep capability: extensive hidden fields and advanced controls are seamlessly integrated for those who demand more.
Optimized for minimal Off-Board and On-Board memory usage.
Full control over: Temperature & Wattage (quick access), Replay, Preheat, Boost, SESSION Mode (Auto Fire)
No wasted space. No unnecessary noise.
Just performance, precision, and complete command.
Pro.Vapers_Manual_EN.pdf
https://youtu.be/aEq-EMRAgBU
Theme Full Info:
Quote
Auto Fire (Session Mode):
Daylight Mode:
Action Center :
Iconic Menus :
Locked Screen:
Main Screen:
System Menu:
Display setting Screen:
USB INFO Screen:
Lock Screen (lock settings):
PowerBank Screen:
Battery Info Screen:
Last Puff Screen:
Live Puff Screen:
Device Info Screen:
Custom Recording Screen:
New Atomizer Screen:
User Toggles Screen:
Diagnostics Screen:
Battery Optimization:
Used Abbreviations:
PWR: Power Mode
TCM: Temperature Control Mode
TC: Temperature Control
Pheat: Preheat
Curnt: Current
Temp: Temperature
ATTY: atomizer
Nrg: Energy
Puff T: Puff Temperature
Batt: Battery
Batts: Battery Pack
Flip Scr: Flip Screen
PWRBank: PowerBank
Cold T: Coil Cold Temperature
Peak: Peak Temperature
Ω Low: Ohm Too Low
Ω High: Ohm Too High
Overheat!: Too Hot
Fire from screens:
Quote
3.
8. Save and Apply changes
Logo1.zipLogo2.zipBrands.zip
a25.gif.9d2953b48bbde38fa695df99ba027d2e.gifIn all versions you can modify screens and access to text icon library. To use icon library, you can choose/select the icon textually on any page or anywhere in the theme.
Versions Info: (SCREENSHOTS)
Quote
The features and menus of all versions are the same, but they are completely different in appearance.
Special Thanks To:
Quote
 Description for Translate.txt
Hope everyone enjoys!
Edited by aMirS
What's New in Version 9.1   See changelog
- Modified portrait version background.
- Added some smart notifications and warnings (all versions).
- Added back button in all fireable screens (all versions).
- Added lock shortcut in LED version main screen.
- Added firing view in LED version main screen.
- Updated icon and logo library(all versions).
- Added customization info &  resources   in theme description. (Includes: 30 custom background, 69 custom logos, 200 icons and mod logos).
- And more features.
  • Like 11
  • Thanks 7
Atlantis
Thanks!
ZumaFx
Kenz0r
Thanks for the amazing work!
JD210991
SIR COILS
· Edited by Sir Coils
Suthiwas
· Edited by Suthiwas
Sflow
Papaws Vape
THANKS AND WELCOME BACK
Jeff_Jeferson
· Edited by Jeff_Jeferson
Perfektní! Pěkná práce.
Mark R
JBoogie
mahmoud
mykl10
LordPuffington
Excellent work.
Very impressed so far.
JOE VAPER
ZebOctets
Is this normal?
mactavish
HaCkStAr
eVape
JPinho
Pcruz
Keep it going.
onnyteam
· Edited by onnyteam
*You are the BEST!!! 🥰
Thelema DNA250C
WLM88
· Edited by WLM88
KRYSS
All the best.🌹
Beefstu2000
