This is an enhanced theme for Evolv DNA color devices. Exposing the full capabilities Priority and care were given to make this theme as clean, functional and intuitive as possible. For designing This theme, numbers of existing theme were studied and their strengths were noted. There are many many hidden fields and functions. Minimum used space (Off-Board memory and On-Board memory usage) Easy Temp & Watt, Replay, Preheat ,Boost and SESSION mode (Auto Fire) Control.
Download Theme Manual:
	Pro.Vapers_Manual_EN.pdf
	https://youtu.be/aEq-EMRAgBU
	Theme Full Info:
QuoteAuto Fire (Session Mode):
Daylight Mode:
Action Center :
In normal mode and when there is no error or incorrect setting, "Action Center" is not displayed, but when an error is detected, this feature is displayed as an icon on the home screen, lock screen and diagnostics screen.Iconic Menus :
Locked Screen:
Main Screen:
The most complete information is displayed on the advance main screen on portrait and default main screen in other versions. At the top of the screen is a battery icon and percentage with the same features as the lock screen. The battery pack voltage is displayed next to it.
System Menu:
Display setting Screen:
USB INFO Screen:
Lock Screen (lock settings):
PowerBank Screen:
Battery Info Screen:
Last Puff Screen:
Live Puff Screen:
Device Info Screen:
Custom Recording Screen:
New Atomizer Screen:
User Toggles Screen:
Diagnostics Screen:
Battery Optimization:
Used Abbreviations:
PWR: Power Mode
TCM: Temperature Control Mode
TC: Temperature Control
Pheat: Preheat
Curnt: Current
Temp: Temperature
ATTY: atomizer
Nrg: Energy
Puff T: Puff Temperature
Batt: Battery
Batts: Battery Pack
Flip Scr: Flip Screen
PWRBank: PowerBank
Cold T: Coil Cold Temperature
Peak: Peak Temperature
Ω Low: Ohm Too Low
Ω High: Ohm Too High
Overheat!: Too Hot
Fire from screens:
QuoteThere are several ways to customize or build a theme based on the Pro Vapers theme .
1. Download the Portrait theme file (*.ecigtheme).
3. Start EScribe and Plug in your device.
8. Save and Apply changes
1. Download the designer edition theme file (*.ecigtheme)
9. Now it should show in EScribe, just upload it to the device by "Upload Settings To Device" at the top of screen.Designers.Edition.Background.zip
In all versions you can modify screens and access to text icon library. To use icon library, you can choose/select the icon textually on any page or anywhere in the theme.
Download icon & logo library manual and copy & paste from pdf to your theme:Pro.Vapers_Icon.Library_EN.pdf
	Versions Info: (SCREENSHOTS)
QuoteThe features and menus of all versions are the same, but they are completely different in appearance.
1- Simple Bold Version is an evolved variant with a simple, clean and modern design with all the features of the chipset. A compilation of all versions.
2- Portrait Version is designed to be quite simple for those who are tired of graphic designs and access to features and simplicity is important.
3- DS and Gold Version is completely graphic. It is the only theme that uses a hand to display an analog ( analogue ) clock.
4- SG Version is a graphical theme that tries to maintain the simple appearance of the portrait version, with the difference that a large slider is displayed around the screen fields and changes color with increasing or decreasing power or temperature.
6- Army version with a simple appearance and silver and blue color for those who like military themes.
Special Thanks To:
CMK aka gwyar, Wayneo, SirTimmyTimbit And all those who gave me ideas in making this theme.
Quote
	 Description for Translate.txt
	Hope everyone enjoys!
Edited by aMirS
What's New in Version 13.6 + Simple Bold See changelog
	Homogenized the screens: text, lines, sizes, etc.
	Added new firing view like live ohm, live voltage and ... in Simple Bold main screen
What's New History
QuoteAdded new features to Action Center to detect wrong user settings.
Updated Main Menu icons and description in the status bar.
Fixed the glitch reported (Temp Protect Error)
USB connection status added to lock screen.
Enable/Disable replay from the Profile screen with any coil material.
Updated highlighted video on Youtube (at the top of this page)
Fixed SG and Simple Bold version on DNA 75C Devices.
The new generation of how to display the menus and settings of the theme has been implemented experimentally in the Simple Bold, Portrait and Designer Edition Versions. (other version stay with classic menus)
fixed battery inductor icons.
Updated to latest firmware .
A new variant called the Simple Bold version has been added in download box. Simple Bold is an evolved variant with a simple, clean and modern design with all the features of the chipset. A compilation of all versions. Try it and DOWNLOAD NOW!!!
The GLC version has been removed from the download box and is available for download on the site with a new title : GLOW CL.
The GMatrix version has been removed from the download box and is available for download on the site with a new title : GMatrix.
The YL version has been removed from the download box and is available for download on the site with a new title : ICONIC YL.
Modified DS and GOLD variants main screen for user friendly use when theme in temperature mode. (Special thanks to @ZebOctets for suggestions).
Add missed power field to profile setup screen for temperature control mode. (Special thanks to @ZebOctets @JOE VAPER for suggestions)
Gview Screen guages Updated.
customization resources in theme description Updated. (More than 200 logo Includes: Boxer, Centaurus, DeadRabbit, Dovpo, Drone, Evolv, Geekvape, HCigar, Hyperion, Lostvape, Mirage, Odin, Paranormal, Rebel, Steam Crave, Thelema, Therion, Thinkvape, Triade, VandyVape, Vapecige, VapersCloud, VaporGiant, Viciousant, Football league teams logo, Marvel characters, Cartoon logos, Girly logos and wallpapers, Skull logos, Cars Companies logos, Mario, Sonic, IOS, Android and ...) Read customization and resources info in theme description for more info and help.
Reduced used spaces.
Reduced used space.
Fixed Army.D version TC mode.
Added customization info & resources in theme description. (Includes: 30 custom background, 69 custom logos, 200 icons and mod logos)
New Silver Beta Version
Modifying Action Center in all variants: Some custom themes have serious bugs in the REPLAY / TC / BOOST implementation. The result is a frustrating disappointment with the promised possibilities of the DNA chipset and the user wonders what he has spent so much money on. "Action Center" screen help you to find and fix incorrect settings or settings not intended by Evolv in each profile. This allows you to rule out incorrect settings of the mod. "Action Center" screen tried to identify problems and at any time it is possible to correct them without the need for a pc or spent more time.
 With version 13.6 + Simple Bold:- Download
