This is an enhanced theme for Evolv DNA color devices. Exposing the full capabilities Priority and care were given to make this theme as clean, functional and intuitive as possible. For designing This theme, numbers of existing theme were studied and their strengths were noted. There are many many hidden fields and functions. Minimum used space (Off-Board memory and On-Board memory usage) Easy Temp & Watt, Replay, Preheat ,Boost and SESSION mode (Auto Fire) Control.
Download Theme Manual:
Pro.Vapers_Manual_EN.pdf
You can watch all the different and unique features of the "Pro Vapers" theme on YouTube.
https://youtu.be/aEq-EMRAgBU
Theme Full Info:
QuoteAuto Fire (Session Mode):
Daylight Mode:
Action Center :
In normal mode and when there is no error or incorrect setting, "Action Center" is not displayed, but when an error is detected, this feature is displayed as an icon on the home screen, lock screen and diagnostics screen.Iconic Menus :
Locked Screen:
Main Screen:
The most complete information is displayed on the advance main screen on portrait and default main screen in other versions. At the top of the screen is a battery icon and percentage with the same features as the lock screen. The battery pack voltage is displayed next to it.
System Menu:
Display setting Screen:
USB INFO Screen:
Lock Screen (lock settings):
PowerBank Screen:
Battery Info Screen:
Last Puff Screen:
Live Puff Screen:
Device Info Screen:
Custom Recording Screen:
New Atomizer Screen:
User Toggles Screen:
Diagnostics Screen:
Battery Optimization:
Used Abbreviations:
PWR: Power Mode
TCM: Temperature Control Mode
TC: Temperature Control
Pheat: Preheat
Curnt: Current
Temp: Temperature
ATTY: atomizer
Nrg: Energy
Puff T: Puff Temperature
Batt: Battery
Batts: Battery Pack
Flip Scr: Flip Screen
PWRBank: PowerBank
Cold T: Coil Cold Temperature
Peak: Peak Temperature
Ω Low: Ohm Too Low
Ω High: Ohm Too High
Overheat!: Too Hot
Fire from screens:
Customization Manual & Resources: (Include devices logo, backgrounds & icons)
QuoteThere are several ways to customize or build a theme based on the Pro Vapers theme .
1. Download the Portrait theme file (*.ecigtheme).
3. Start EScribe and Plug in your device.
8. Save and Apply changes
1. Download the designer edition theme file (*.ecigtheme)
9. Now it should show in EScribe, just upload it to the device by "Upload Settings To Device" at the top of screen.Designers.Edition.Background.zip
In all versions you can modify screens and access to text icon library. To use icon library, you can choose/select the icon textually on any page or anywhere in the theme.
Download icon & logo library manual and copy & paste from pdf to your theme:Pro.Vapers_Icon.Library_EN.pdf
Versions Info: (SCREENSHOTS)
QuoteThe features and menus of all versions are the same, but they are completely different in appearance.
1- Simple Bold Version is an evolved variant with a simple, clean and modern design with all the features of the chipset. A compilation of all versions.
2- Portrait Version is designed to be quite simple for those who are tired of graphic designs and access to features and simplicity is important.
3- DS and Gold Version is completely graphic. It is the only theme that uses a hand to display an analog ( analogue ) clock.
4- SG Version is a graphical theme that tries to maintain the simple appearance of the portrait version, with the difference that a large slider is displayed around the screen fields and changes color with increasing or decreasing power or temperature.
6- Army version with a simple appearance and silver and blue color for those who like military themes.
Special Thanks To:
CMK aka gwyar, Wayneo, SirTimmyTimbit And all those who gave me ideas in making this theme.
Other Themes based on Pro Vapers: (Include 5 themes)
Quote
Description for Translate.txt
Hope everyone enjoys!
Edited by aMirS
