This is an enhanced theme for Evolv DNA color devices. Exposing the full capabilities Priority and care were given to make this theme as clean, functional and intuitive as possible. For designing This theme, numbers of existing theme were studied and their strengths were noted. There are many many hidden fields and functions. Minimum used space (Off-Board memory and On-Board memory usage) Easy Temp & Watt, Replay, Preheat ,Boost and  SESSION mode (Auto Fire) Control.
Pro.Vapers_Manual_EN.pdf
https://youtu.be/aEq-EMRAgBU
Theme Full Info:
Quote
Auto Fire (Session Mode):
Daylight Mode:
Action Center :
Iconic Menus :
Locked Screen:
Main Screen:
System Menu:
Display setting Screen:
USB INFO Screen:
Lock Screen (lock settings):
PowerBank Screen:
Battery Info Screen:
Last Puff Screen:
Live Puff Screen:
Device Info Screen:
Custom Recording Screen:
New Atomizer Screen:
User Toggles Screen:
Diagnostics Screen:
By pressing the "Diagnostics" or Wrench icon in system menu you will be directed to the Diagnostics screen
Battery Optimization:
Used Abbreviations:
PWR: Power Mode
TCM: Temperature Control Mode
TC: Temperature Control
Pheat: Preheat
Curnt: Current
Temp: Temperature
ATTY: atomizer
Nrg: Energy
Puff T: Puff Temperature
Batt: Battery
Batts: Battery Pack
Flip Scr: Flip Screen
PWRBank: PowerBank
Cold T: Coil Cold Temperature
Peak: Peak Temperature
Ω Low: Ohm Too Low
Ω High: Ohm Too High
Overheat!: Too Hot
Fire from screens:
Quote
3.
8. Save and Apply changes
Logo1.zipLogo2.zipBrands.zip
a25.gif.9d2953b48bbde38fa695df99ba027d2e.gifIn all versions you can modify screens and access to text icon libraryTo use icon library, you can choose/select the icon textually on any page or anywhere in the theme.
Versions Info: (SCREENSHOTS)
Quote
The features and menus of all versions are the same, but they are completely different in appearance
Special Thanks To:
Quote
 Description for Translate.txt
Hope everyone enjoys!
Edited by aMirS
What's New in Version 13.7 + DS UI   See changelog
Homogenized the screens: text, lines, sizes, etc.
DS variant Lock Screen redesigned.
What's New History
Quote
Added new firing view like live ohm, live voltage and ... in Simple Bold main screen
Added new features to Action Center to detect wrong user settings.
Updated Main Menu icons and description in the status bar.
Fixed the glitch reported (Temp Protect Error)
USB connection status added to lock screen.
Enable/Disable replay from the Profile screen with any coil material.
Updated highlighted video on Youtube (at the top of this page)
Fixed SG and Simple Bold version on DNA 75C Devices.
The new generation of how to display the menus and settings of the theme has been implemented experimentally in the Simple Bold, Portrait and Designer Edition Versions. (other version stay with classic menus)
fixed battery inductor icons.
Updated to latest firmware .
A new variant called the Simple Bold version has been added in download box. Simple Bold is an evolved variant with a simple, clean and modern design with all the features of the chipset. A compilation of all versions. Try it and DOWNLOAD NOW!!!
The GLC version has been removed from the download box and is available for download on the site with a new title : GLOW CL.
The GMatrix version has been removed from the download box and is available for download on the site with a new title : GMatrix.
The YL version has been removed from the download box and is available for download on the site with a new title : ICONIC YL.
Modified DS and GOLD variants main screen for user friendly use when theme in  temperature mode. (Special thanks to @ZebOctets  for suggestions).
Add missed power field to profile setup screen for temperature control mode. (Special thanks to @ZebOctets @JOE VAPER for suggestions)
Gview Screen guages Updated.
customization resources in theme description Updated. (More than 200 logo Includes: Boxer, Centaurus, DeadRabbit, Dovpo, Drone, Evolv, Geekvape, HCigar, Hyperion, Lostvape, Mirage, Odin, Paranormal, Rebel, Steam Crave, Thelema, Therion, Thinkvape, Triade, VandyVape, Vapecige, VapersCloud, VaporGiant, Viciousant, Football league teams logo, Marvel characters, Cartoon logos, Girly logos and wallpapers, Skull logos, Cars Companies logos, Mario, Sonic, IOS, Android  and ...) Read customization and resources info in theme description for more info and help.
Reduced used spaces.
Reduced used space.
Fixed Army.D version TC mode.
Added customization info & resources  in theme description. (Includes: 30 custom background, 69 custom logos, 200 icons and mod logos)
New Silver Beta Version
Modifying Action Center in all variants: Some custom themes have serious bugs in the  REPLAY / TC / BOOST implementation. The result is a frustrating disappointment with the promised possibilities of the DNA chipset and the user wonders what he has spent so much money on. "Action Center" screen help you to find and fix incorrect settings or settings not intended by Evolv in each profile. This allows you to rule out incorrect settings of the mod. "Action Center" screen tried to identify problems and at any time it is possible to correct them without the need for a pc or spent more time.
  • Like 11
  • Thanks 7
Atlantis
Thanks!
ZumaFx
Kenz0r
Thanks for the amazing work!
JD210991
SIR COILS
· Edited by Sir Coils
Suthiwas
· Edited by Suthiwas
Sflow
Papaws Vape
THANKS AND WELCOME BACK
Jeff_Jeferson
· Edited by Jeff_Jeferson
Perfektní! Pěkná práce.
Mark R
JBoogie
mahmoud
mykl10
LordPuffington
Excellent work.
Very impressed so far.
JOE VAPER
ZebOctets
Is this normal?
mactavish
HaCkStAr
eVape
JPinho
Pcruz
Keep it going.
onnyteam
· Edited by onnyteam
*You are the BEST!!! 🥰
Thelema DNA250C
WLM88
· Edited by WLM88
KRYSS
All the best.🌹
Beefstu2000
