Jimmi5 Posted December 27, 2023 Report Share Posted December 27, 2023 At a loss so I’ll just post my issue here. I have a dna 60 that is fine all day but when I wake up it’s auto firing and I can’t get it to stop. It DOES have secondary fire button (which I have temporarily removed) and Ive even gone ahead and removed the cap and silicone button in tact switch on the main board . She still will auto fire even with no button. Next step, I thought it must be the board so I swapped it with another . Worked perfect for a week now this board doing the same thing . I did put the same theme and firmware on the new board (idk if that makes a difference) but even with the new boards buttons discoed the same thing is happening. Suggestions on where to focus now ? Link to comment Share on other sites More sharing options...
dwcraig1 Posted December 27, 2023 Report Share Posted December 27, 2023 Well the theme on a 60 is just a bunch of images with no control. What about session mode, is that off. Pretty unusual problem. DNA60's is what I mostly use. Any little strands of wire sticking about? Link to comment Share on other sites More sharing options...
BillW50 Posted December 27, 2023 Report Share Posted December 27, 2023 Gosh @Jimmi5, two DNA60 auto firing... what is the make and model of this mod? My first thought is if there is some juice leaking on the boards? Link to comment Share on other sites More sharing options...
Jimmi5 Posted December 28, 2023 Author Report Share Posted December 28, 2023 It’s an Astro by mission Xv . At first I thought it was a stray wire or bad solder connection( I’m still convinced something is shorting) it’s just so odd that it will work perfectly fine all day then auto fire in the middle of night when no one is using it Link to comment Share on other sites More sharing options...
Wayneo Posted December 28, 2023 Report Share Posted December 28, 2023 It should still be under Manufacturer warranty. I'd return it to place of purchase or ask Mission. It does not sound like a board problem. 1 Link to comment Share on other sites More sharing options...
BillW50 Posted December 29, 2023 Report Share Posted December 29, 2023 15 hours ago, Jimmi5 said: It’s an Astro by mission Xv . At first I thought it was a stray wire or bad solder connection( I’m still convinced something is shorting) it’s just so odd that it will work perfectly fine all day then auto fire in the middle of night when no one is using it Oh man! Those are so sweet! They use that double firing switch design. I'd be looking there for your short. Maybe just disassemble it and repositioning things and put it back together might be all that is needed. And Wayneo's idea isn't bad either if that is still an option. 1 Link to comment Share on other sites More sharing options...
Jimmi5 Posted December 29, 2023 Author Report Share Posted December 29, 2023 It is the day one version from 2022. It’s sweet but it’s also my daily driver. I don’t want to send it unless I have no choice. I swapped the chip again and it’s working fine again. I still didn’t see any obvious shorts. Idk , we will see if it stays working this time. I’m not convinced but I am hopeful . Thanks guys 2 Link to comment Share on other sites More sharing options...
dwcraig1 Posted December 29, 2023 Report Share Posted December 29, 2023 Did you put the first one back in or is a 3rd one? 1 Link to comment Share on other sites More sharing options...
Jimmi5 Posted December 29, 2023 Author Report Share Posted December 29, 2023 3rd one, I sacrificed my orca because the frame was cracked .. so far no issues Link to comment Share on other sites More sharing options...
