kory Posted January 16, 2023 Report Posted January 16, 2023 i am fairly new to dna chip but have some experience with my lost vape orion plus. I built my tank with ohm centric 27/36 n80 aliens coils (5 wrap 3mm .12 ohm) i checked ohms and it is correct. my question is, is there any good starting points for my mod i feel it has slow ramp up also any suggestions to get the best out of my setup? thanks in advance!
BillW50 Posted January 16, 2023 Report Posted January 16, 2023 Slow ramp up means it is time to turn on boost and/or increase it. 1
kory Posted January 16, 2023 Author Report Posted January 16, 2023 Thanks for the quick response is there an ideal wattage or mode i should be in? Or a recommended starting point?
Wayneo Posted January 16, 2023 Report Posted January 16, 2023 Did you move directly to this mod after your Orion? What watts are you currently using? Did you turn the Boost Punch on/up as already suggested? 1
kory Posted January 16, 2023 Author Report Posted January 16, 2023 No i was back and forth between that and a voopoo drag i did turn it up to +5 and currently have it around 70 watts. I honestly haven’t played around too much as i dont want to mess anything up
BillW50 Posted January 16, 2023 Report Posted January 16, 2023 Like always start your wattage low and start increasing it. You'll find a wattage that you like. But if you go too far, you'll get a dry puff. 1
kory Posted January 17, 2023 Author Report Posted January 17, 2023 And idea if this is a good rda or any chance you know of like top 3 that you can buy?
Wayneo Posted January 17, 2023 Report Posted January 17, 2023 I have not heard anything bad, but not my style of vape. Watch reviews on it, or find a generalized vaping forum. I usually run my single battery mods with a single coil atty/rda, but nothing wrong at all with your setup 1
