William Deckard Posted August 24, 2022 Report Share Posted August 24, 2022 (edited) Folks, Has anyone here swapped the chipset on the original non Evolv board version? I've got a non working mod and I'd love to swap the crappy Dovpo board with a DNA 60. Cheers. Edited August 24, 2022 by William Deckard Link to comment Share on other sites More sharing options...
BillW50 Posted August 24, 2022 Report Share Posted August 24, 2022 There is a guy in a Facebook group that converts them over to DNA60. So it shouldn't be that hard. They also have the Abyss Stormtrooper DNA60 too. Have you seen those? Those are made from white Delrin instead of SS. And they also come with the SbS kit with larger battery caps. 1 Link to comment Share on other sites More sharing options...
Wayneo Posted August 24, 2022 Report Share Posted August 24, 2022 The datasheet shows the pin-outs for the DNA board. Page 11.https://downloads.evolvapor.com/dna60.pdf 2 Link to comment Share on other sites More sharing options...
William Deckard Posted August 24, 2022 Author Report Share Posted August 24, 2022 Will I be able to use the USB C charge port on the Abyss, if I can do I have to modify it in any way? Link to comment Share on other sites More sharing options...
BillW50 Posted August 24, 2022 Report Share Posted August 24, 2022 Yes you can use the USB-C port with the DNA60. ECigStats won't find the ECigStats site, but everything else like EScribe works. 1 Link to comment Share on other sites More sharing options...
Wayneo Posted August 24, 2022 Report Share Posted August 24, 2022 17 minutes ago, William Deckard said: Will I be able to use the USB C charge port on the Abyss, if I can do I have to modify it in any way? Pins 11-15 in that datasheet and you'll need a 10k ohm resistor. Ideally their charger will have some stuff written on it 1 Link to comment Share on other sites More sharing options...
William Deckard Posted August 24, 2022 Author Report Share Posted August 24, 2022 (edited) Thanks for all the helpful answers, folks! Do you know which specific pin the 10k resistor goes to? Edited August 24, 2022 by William Deckard added detail Link to comment Share on other sites More sharing options...
Wayneo Posted August 24, 2022 Report Share Posted August 24, 2022 It's clearly identified in the datasheet 👍 Page 11 1 Link to comment Share on other sites More sharing options...
Laservape Posted March 30, 2023 Report Share Posted March 30, 2023 On 8/24/2022 at 12:32 PM, William Deckard said: Folks, Has anyone here swapped the chipset on the original non Evolv board version? I've got a non working mod and I'd love to swap the crappy Dovpo board with a DNA 60. Cheers. How did you get on mate? Did you manage to do it? I’m looking at doing the same now but really could do with some good advice on eveything you needed. Link to comment Share on other sites More sharing options...
