HumanZombie Posted September 29, 2021 Report Posted September 29, 2021 I recently picked up a Kennedy box mod and was searching for instructions but this mod is almost non existent according to the internet. I have figured out how to change the modes and adjust the watts but whenever I am in TC mode the screen simply says off, all while the mod still works. I am just trying to figure out what is going on and how to change it. If anyone knows how to use or has an instruction manual for a Kennedy I would appreciate the help!
retird Posted September 30, 2021 Report Posted September 30, 2021 Lots of info that may help can be seen/downloaded and etc. The datasheet has a lot of info. EScribe software is also very beneficial.. Assuming th Kenedy has the DNA250 board... https://www.evolvapor.com/products/dna250 More links: https://www.google.com/search?q=Kennedy+box+mod&rlz=1C1CHBF_enUS840US840&oq=Kennedy+box+mod&aqs=chrome..69i57j0i22i30l4j69i60l2.17821j0j15&sourceid=chrome&ie=UTF-8 https://www.google.com/search?q=kennedy+box+mod&rlz=1C1CHBF_enUS840US840&source=lnms&tbm=vid&sa=X&ved=2ahUKEwiElNmjxaXzAhXVgGoFHd63B68Q_AUoA3oECAEQBQ&biw=1600&bih=937&dpr=1 1
HumanZombie Posted September 30, 2021 Author Report Posted September 30, 2021 It does have a dna 250 I checked. And I've looked through all that information but I cant find even a screen that says off. I even changed the theme using escribe hoping it would change but alas nothing. I've been trying to upload a picture of the screen but the upload on this site seems to not work. SO i did this:https://imgur.com/a/LE8ISoO
BillW50 Posted September 30, 2021 Report Posted September 30, 2021 (edited) It is in temperature mode (TC) and the temperature is set to off, or it automatically kicked itself off when it sensed a non temperature material (coil). If you are using non-TC coil, you need to switch to wattage or aka power mode profile. This button command list I written for the DNA200, but it applies to most non-color DNAs including the DNA250. DNA200 OPERATIONAL MANUAL MAIN Up/Down (5 sec) lock wattage or temp (Temp-Dominant dependent) Up/Down (5 sec) then twice Up (or Down) to change Profile LOCK (5 clicks) Up/Down (5 sec) adjusts temp or wattage (Temp-Dominant dependent) Fire/Up (5 sec) lock ohms Fire/Dn (5 sec) Stealth/Normal Fire/UD (5 sec) Change Material Edited September 30, 2021 by BillW50
