mix11898 Posted July 21, 2021 Report Posted July 21, 2021 (edited) I have tried to run the case analyzer, and the result is below as you can see below. The thing is when I click to upload it to Dovpo Riva DNA250c There were the alert popped up saying "Case Static Temperature Rise is very high, and may be wrong. To change Thermal settings such as Case Static Temperature Rise, go to the Mod Tab. Program as is?" For more information, just to be more clear on the factor, I have set the Fahrenheit to around 84°F as I live in Thailand, the country where the normal temperature is hotter than Europe. 1.Is there anything wrong with my case analyzing? Anyway, I also have other 2 questions about the escribe and TC. 2. Do case analyzing and battery analyzing effect that much on the accuracy of the temperature control? 3. Also in the theme section what is the different between "Coil cold Ohms" and "Coil cold Ohms at 70°F? Edited: My bad i put this post in the wrong forum, I have to apologise to you guys Admins. Edited July 21, 2021 by mix11898
Wayneo Posted July 21, 2021 Report Posted July 21, 2021 2 hours ago, mix11898 said: There were the alert popped up saying "Case Static Temperature Rise is very high, and may be wrong. To change Thermal settings such as Case Static Temperature Rise, go to the Mod Tab. Program as is?" It is high as the popup showed. So what did you do, or what's in that field now? 2 hours ago, mix11898 said: .... I have set the Fahrenheit to around 84°F ... What do you mean? Where have you set this? 2 hours ago, mix11898 said: 2. Do case analyzing and battery analyzing effect that much on the accuracy of the temperature control? Case Analyzer - Yes it can, but nothing too great. Battery Analyzer is really cosmetic for your icon or % to be more accurate 1 1
mix11898 Posted July 21, 2021 Author Report Posted July 21, 2021 Thanks for the replying Wayneo 14 minutes ago, Wayneo said: It is high as the popup showed. So what did you do, or what's in that field now? It's 24.24 F as you can see in the screenshot. It is the result I got after the case analyzing 15 minutes ago, Wayneo said: What do you mean? Where have you set this? What I meant for 84F is that when I start the case analyzer, I have to put in the room temperature right? So it is usually around 28-32 celsius in Thailand. That's why I have to put 84F when I started the case analyzer.
Wayneo Posted July 21, 2021 Report Posted July 21, 2021 1 hour ago, mix11898 said: It's 24.24 F as you can see in the screenshot. It is the result I got after the case analyzing I'd run it again if it were me, or at least until you got 2 with similar values. My mods are all different, 0, 5, 8F. If you hover over that field it'll show a description. If that 84F was right, that's good. Edit #2: Do you own any non color DNA mods? Edit: Here's a video I've recommended before. There are very good points in there. https://youtu.be/BlVWc49qbPY
mix11898 Posted July 22, 2021 Author Report Posted July 22, 2021 5 hours ago, Wayneo said: I'd run it again if it were me, or at least until you got 2 with similar values. My mods are all different, 0, 5, 8F. If you hover over that field it'll show a description. If that 84F was right, that's good. Edit #2: Do you own any non color DNA mods? Edit: Here's a video I've recommended before. There are very good points in there. https://youtu.be/BlVWc49qbPY Okay thanks a lot Wayneo. ☺️ I'll try it again when I can. I do own the colour screen. it's Dovpo Riva 250c as I mentioned.
Wayneo Posted July 22, 2021 Report Posted July 22, 2021 9 hours ago, mix11898 said: I do own the colour screen. it's Dovpo Riva 250c as I mentioned. Yes, thank you, I was aware of that but my question was 15 hours ago, Wayneo said: Edit #2: Do you own any non color DNA mods? DNA mods that have a black and white screen?
mix11898 Posted July 22, 2021 Author Report Posted July 22, 2021 7 minutes ago, Wayneo said: Yes, thank you, I was aware of that but my question was DNA mods that have a black and white screen? Of course, it's DNA250c, it is not black and white.
Wayneo Posted July 22, 2021 Report Posted July 22, 2021 I will ask a different way. how many DNA mods do you own?
zark Posted July 23, 2021 Report Posted July 23, 2021 On 21.07.2021 at 22:58, Wayneo said: Case Analyzer - Да, может, но ничего особенного. Battery Analyzer действительно косметический для вашего значка или%, если быть более точным Case Analyzer влияет на скорость зарядки батарей. Чип DNA на основе полученных данных управляет продолжительностью импульсов заряда, чтобы не допустить перегрева платы. Так же на основе данных Case Analyzer процессор высчитывает комнатную температуру. По этому данный тест очень ничтожно влияет на контроль температуры, но глобально влияет на правильность контроля температуры чипа при использовании 2
mix11898 Posted July 23, 2021 Author Report Posted July 23, 2021 On 7/22/2021 at 8:22 PM, Wayneo said: I will ask a different way. how many DNA mods do you own? Okay that's my bad 😂 ,so sorry that I overlook the sentences. (My gosh, I'm so embarrassed) For the questions, of course, yes I have just bought secondhand HCigar VT Inbox DNA75. It should be arrived tomorrow.
Wayneo Posted July 24, 2021 Report Posted July 24, 2021 On 7/23/2021 at 10:21 AM, mix11898 said: yes I have just bought secondhand HCigar VT Inbox DNA75. It should be arrived tomorrow. No worries my good man, and now I can answer your last unanswered question On 7/21/2021 at 12:54 PM, mix11898 said: 3. Also in the theme section what is the different between "Coil cold Ohms" and "Coil cold Ohms at 70°F? Quick answer - Its so you can compare the coil Ω's between b&w and color mods. In the DNA world, it is not required, and many do not 'lock ohms' for TC vaping, which defeats 'refinement'. On a fully configured (non-color or b&w) mod, the Ω's will 'refine' (usually lower) to their resistance at 70°F On a fully configured color mod, the Ω's will be written into the mod at the current temp. BUT if you were to use that (at 70°F) option, it should be close to your b&w mod. 1
