jinx'd Posted February 25, 2021 Report Share Posted February 25, 2021 anyone seen this ? this is on a hardly used Drone. the black spot is so even its like i tried to draw a perfect oval thanx Link to comment Share on other sites More sharing options...
dwcraig1 Posted February 25, 2021 Report Share Posted February 25, 2021 3 hours ago, jinx'd said: anyone seen this ? this is on a hardly used Drone. the black spot is so even its like i tried to draw a perfect oval thanx https://forum.evolvapor.com/topic/70812-display-gone-bad/ 1 Link to comment Share on other sites More sharing options...
jinx'd Posted February 25, 2021 Author Report Share Posted February 25, 2021 thanx. that is exactly what mine looks like. but offers no solution other than arbitrarily replacing the screen, which is probably what it is. but, the little use i have on mine leads me to believe there is a defect in these screens. and/or there is some other problem. as you know, the Drones are prone to leaking, and mine did. as soon as it started to leak i immediately stopped sqounking it and cleaned. then i sparingly used it as a regular mod, which was ok with me. after very little use it was then turned into an ohm checker on new coils. on one of the coil checks i noticed this blotch. Link to comment Share on other sites More sharing options...
BillW50 Posted February 25, 2021 Report Share Posted February 25, 2021 That spot occurs when juice gets inside of the screen. Link to comment Share on other sites More sharing options...
jinx'd Posted February 25, 2021 Author Report Share Posted February 25, 2021 ok. but does it get in every screen the same way ? = that perfectly oblong splotch. seems odd to me, but what do i know. Link to comment Share on other sites More sharing options...
BillW5 Posted February 25, 2021 Report Share Posted February 25, 2021 I'm still BillW50, I just can't sign in on that account right now. Yes it looks the same whenever juice gets inside of the screen. I figure the juice gets inside where the ribbon wire is attached. And the same area gets juiced every time. Thus results in the same blacked out pattern. Link to comment Share on other sites More sharing options...
jinx'd Posted February 25, 2021 Author Report Share Posted February 25, 2021 ok, thanx Bill. looks like i will be placing an order Link to comment Share on other sites More sharing options...
