dwcraig1 Posted December 8, 2020 Report Posted December 8, 2020 Try to keep it 220 C degrees or lower. If you want to use spaced coils try making the wraps closer together. I use contact coils only but many prefer spaced, your choice. Try to keep the whole coil in the air flow.
Djini Biba Posted December 8, 2020 Author Report Posted December 8, 2020 Так он не жарит на 220 Как я предполагаю .титан и никель особенно .Чтоб мощно было включаю больше. why do I need to completely restart the Board, return the initial settings so that the fleece does not burn ?You will see what I measured the resistance of the internal mod!And tell me the difference is if I cut a little less than half will be in the resistance.whether the difference awakens resistance .100mm copper stick The country is still that increases above 220 to 230. curve graph.
dwcraig1 Posted December 8, 2020 Report Posted December 8, 2020 Are you setting your cold resistance again after the coil is heated? If so it will use that setting as the cold resistance and be hotter than what it reports.
dwcraig1 Posted December 8, 2020 Report Posted December 8, 2020 If your mod's resistance is 0.004 ohm and you set it to 0.002 or 0.005 it will make almost no difference to your problem.
Djini Biba Posted December 8, 2020 Author Report Posted December 8, 2020 37 minutes ago, dwcraig1 said: Вы снова устанавливаете сопротивление холоду после нагрева катушки? В этом случае он будет использовать эту настройку в качестве сопротивления холоду и будет горячее, чем указано в сообщении. По разному и так и так .В основном нагреваю ,чтоб согреть от холода с окна идёт .И жду когда согреется с модом сольётся и остынет . И жду когда катушка примет последний минимальный ом самый маленький . In different ways and so and so .Mostly I heat it to keep it warm from the cold from the window .And I'm waiting for it to warm up with the mod and merge and cool down . And I'm waiting for the coil to take the last minimum Ohm the smallest . And I take idle puffs
Djini Biba Posted December 8, 2020 Author Report Posted December 8, 2020 Вот из-за этого может сушить мою вата ? как я понимаю везде в профилях должно стоять ноль градусы нужно ставить на ноль?во всех профилях ?
dwcraig1 Posted December 8, 2020 Report Posted December 8, 2020 If preheat (1 watt) is set lower than power (33 watts) it has no effect. 1
Wayneo Posted December 8, 2020 Report Posted December 8, 2020 Y'ever seen a board temp of 154°C DW? That'd be like 309.2°F
dwcraig1 Posted December 9, 2020 Report Posted December 9, 2020 I did see the "B" but at the time didn't realize it was "Board" I think you have found the problem......or a problem. Earlier screen shots doesn't show it that hot.
Wayneo Posted December 9, 2020 Report Posted December 9, 2020 I don't think it's a board problem, I think it's a user caused problem. Many of his DM posts show they're just Device Monitor puffs. No airflow through those/that coil so it just sits there cooking.
