Djini Biba Posted November 26, 2020 Report Share Posted November 26, 2020 1-cut the copper thread. But the resistance jumps from 0.004 to 0.003! The standard manufacturer is 0.004. I don't understand why this is happening, it seems like it should not jump. The copper itself is long in the photo. 2-cotton wool and the temperature without a wick during thermal control to light at 3 watts? and the temperature? on the nerzhe. Shouldn't it be like that? that is, to zero? That is, without cotton wool, do not turn on? Without cotton wool, it gives out 3 wool 2 wool Link to comment Share on other sites More sharing options...
BillW50 Posted November 26, 2020 Report Share Posted November 26, 2020 (edited) Do you have EScribe handy @Djini Biba and what does the Atomizer Analyzer show? 0.004Ω is the default Evolv setting I believe. Also the threaded rod is only screwed finger tight? If so, it might need to be just a tad tighter (less than 1/30th of a turn). Edited November 26, 2020 by BillW50 Link to comment Share on other sites More sharing options...
Djini Biba Posted November 27, 2020 Author Report Share Posted November 27, 2020 Do you mean manually? Twists like a drip! I screw it up to the end. As I understand it 1/30 Is it not necessary to screw it up to the end? Yes, I use the analyzer. Even if at 1/30 there is either 0.004 or 0.003 Link to comment Share on other sites More sharing options...
Wayneo Posted November 27, 2020 Report Share Posted November 27, 2020 7 hours ago, Djini Biba said: Even if at 1/30 there is either 0.004 or 0.003 Use the lower number. 0.003 1 Link to comment Share on other sites More sharing options...
Djini Biba Posted November 27, 2020 Author Report Share Posted November 27, 2020 fully screwed in 0.004 Link to comment Share on other sites More sharing options...
Djini Biba Posted December 1, 2020 Author Report Share Posted December 1, 2020 On 27.11.2020 at 20:04, Wayneo said: Используйте меньшее число. 0,003 Почему у меня мод перестал видеть rda. На механическом работает ,на другой плате работает.DNA видит другие дрипки .Эту нет .Может ластиком натер .. Чем протереть Контакты мода и rda? И ответь на второй вопрос когда ватка вставлена в спираль без жидкости ,при термоконтроле должно ноль ват быть?А не 3?и не два?фото посмотри 4! Why my mod stopped seeing rda. It works on a mechanical Board ,but it works on another Board.DNA sees other drips .This one isn't .Maybe he rubbed it with an eraser .. How do I wipe the mod and rda Contacts? And answer the second question when the cotton wool is inserted into the spiral without liquid, when the thermal control should be zero cotton wool?Not 3?and not two?look at 4 photos! Link to comment Share on other sites More sharing options...
Wayneo Posted December 1, 2020 Report Share Posted December 1, 2020 I have a feeling that you pushed the insulator downward a bit with that threaded rod and now this atty with the shortest 510 no longer makes contact. Can you feel any movement in that spring loaded 510 positive pin? You might need to unscrew the 510 to fix it. No photos attached! But your mod will still fire with no cotton or liquid even if it's in TC. 2 Link to comment Share on other sites More sharing options...
Djini Biba Posted December 1, 2020 Author Report Share Posted December 1, 2020 Были такие ощущения , искривлён был первый раз ,Мне. Тогда не показалось значит.Спасибо я немного слабенько сбоку его приподнял . он с любым материалом в режиме тк вата горит немного румянится без жидкости! тоесть 3 вата включает постоянно и вата немного жёлтая . Либо чёрная на титане. There were such feelings, it was twisted for the first time ,to Me. Then it didn't seem so.Thanks, I lifted it a little weakly from the side . it is with any material in the mode of TC cotton wool burns a little blush without liquid! ie 3 Vata includes constantly and Vata a little yellow . Or black on titanium. Link to comment Share on other sites More sharing options...
Wayneo Posted December 1, 2020 Report Share Posted December 1, 2020 Is your 510 positive pin springy now? Does your mod see that atty now? I clean my wire before a dry burn, or I pulse clapton wire before use to burn off any oils. Once coiled, l smell the coil during that pulse till they smell clean. Once there is cotton in the coil, I add juice, still at a low watts till the coil is saturated. Then I put on the barrel of the tank/RTA/RDA, fill and vape. I do not see your yellow or black. 1 Link to comment Share on other sites More sharing options...
Djini Biba Posted December 2, 2020 Author Report Share Posted December 2, 2020 Насчёт пружины не знаю .Да теперь видит ! на титане .Вата горит Link to comment Share on other sites More sharing options...
Djini Biba Posted December 2, 2020 Author Report Share Posted December 2, 2020 (edited) Никель это ni200 Edited December 2, 2020 by Djini Biba Link to comment Share on other sites More sharing options...
