Francisco Posted November 1, 2020 Report Posted November 1, 2020 After a thousand tries, I can't remove the total puffs from the screen, I can't find in Scribe how to do it. Can anybody help me please ???.
Wayneo Posted November 1, 2020 Report Posted November 1, 2020 You need to use the 'Theme Designer', find the screen where it is, then the field you want to remove. Delete the 'field', save and upload to your mod. 1
Francisco Posted November 2, 2020 Author Report Posted November 2, 2020 Hace # [1:hora][?:horas]}, Wayneo dijo: Debe usar el 'Diseñador de temas', buscar la pantalla donde está y luego el campo que desea eliminar. Elimina el 'campo', guarda y sube a tu mod. Thank you very much. I was going crazy trying all the options. I will do what you tell me and comment on the final results. Thanks again.
Francisco Posted November 3, 2020 Author Report Posted November 3, 2020 Sorry Wayneo, my question was not correct. My question really is, how to reset the puff counter ???. thanks for your attention.
Wayneo Posted November 3, 2020 Report Posted November 3, 2020 Escribe - Device Monitor - Reset statistics (Down near the bottom right hand corner). That will reset current puffs to zero. The grand total cannot be reset to zero.
BillW50 Posted November 14, 2020 Report Posted November 14, 2020 I would love to reset the counter to any value I wanted to. For example, if I know a coil has 3981 puffs on it and put it on a different mod, I'd love to set that puff counter to 3981 puffs instead of 0.
TorturedZen Posted November 18, 2020 Report Posted November 18, 2020 On 11/14/2020 at 9:30 AM, BillW50 said: if I know a coil has 3981 puffs on it and put it on a different mod Sounds like a good idea. If it can be done, which I have no clue, the other mod would probably need to be a DNA also. 1
