Pigsy Posted October 27, 2020 Report Posted October 27, 2020 I recently bought a Prisma DNA 75c, i have downloaded the Evlolv replay theme on to it. My problem is once it has locked i unlock it and everytime it shows check atomiser from 2 to 5 times then it will fire and be ok until it locks again. I have checked the atty is tight and tried other atties aswell but still does the same thing, I downloaded another theme to check it wasnt that and i am now stumped. Any help would be much appreciated please.
Podunk Steam Posted October 27, 2020 Report Posted October 27, 2020 (edited) Clearo atty? Coil material? Mod resistance set? Ohms read from a room temp mod and atty? Clean battery contacts? Edited October 27, 2020 by Podunk Steam Because we like you 2
dwcraig1 Posted October 28, 2020 Report Posted October 28, 2020 Try using Atomizer Analyzer in EScribe to see if atty has a connection or not and post findings. 2
Pigsy Posted October 28, 2020 Author Report Posted October 28, 2020 12 hours ago, Podunk Steam said: Clearo atty? Coil material? Mod resistance set? Ohms read from a room temp mod and atty? Clean battery contacts? The atty is a 24mm Dvarw The coil is a MTL clapton all ni80 (pc coils) Sorry how would i find room temp for mod & atty ? Battery contacts are all clean.
Pigsy Posted October 28, 2020 Author Report Posted October 28, 2020 9 hours ago, dwcraig1 said: Try using Atomizer Analyzer in EScribe to see if atty has a connection or not and post findings. Will do this when i get home from work, should i do this before i fire the mod ? Sorry don't know how to post findings but will have a look.
Wayneo Posted October 28, 2020 Report Posted October 28, 2020 7 minutes ago, Pigsy said: should i do this before i fire the mod ? Sorry don't know how to post findings but will have a look. Shouldn't matter with N80, but I'd do it before. Let us know if the ohms fluctuates, and how much. Did this always happen, since new? 1
Pigsy Posted October 28, 2020 Author Report Posted October 28, 2020 Just now, Wayneo said: Shouldn't matter with N80, but I'd do it before. Let us know if the ohms fluctuates, and how much. Did this always happen, since new? I thought it best to do it before as thats when the problem is. Yes this has happened from day one, only had it 6 weeks. Thought it maybe the theme so changed it as i wasn't keen on it anyway.
Pigsy Posted October 28, 2020 Author Report Posted October 28, 2020 Ok i done the atomizer analyzer before firing it.... Ohms 1.067 Raw Ohms 1.071 Mod Resistance 0.004 Room Temp 67.41°F When fired showed the check atomiser twice and now works fine, hope this helps.
dwcraig1 Posted October 28, 2020 Report Posted October 28, 2020 It is not meant to fix anything just info. Do this: Start Atomizer with no atty. Now start screwing in atty. Note how many turns or partial turns from where Atomizer Analyzer starts reading ohms till it's screwed in all the way. 1
Pigsy Posted October 28, 2020 Author Report Posted October 28, 2020 34 minutes ago, dwcraig1 said: It is not meant to fix anything just info. Do this: Start Atomizer with no atty. Now start screwing in atty. Note how many turns or partial turns from where Atomizer Analyzer starts reading ohms till it's screwed in all the way. It goes in one full turn then starts reading ohms, reads 1.2 ohms and all the way in it reads 1.076 1
Podunk Steam Posted October 28, 2020 Report Posted October 28, 2020 (edited) 8 hours ago, Pigsy said: The atty is a 24mm Dvarw The coil is a MTL clapton all ni80 (pc coils) Sorry how would i find room temp for mod & atty ? Battery contacts are all clean. Try using temperature sensing capable wire for your coils. Edited October 28, 2020 by Podunk Steam
Pigsy Posted October 28, 2020 Author Report Posted October 28, 2020 46 minutes ago, Podunk Steam said: Try using temperature sensing capable wire for your coils. I don't have replay turned on in escribe for that profile !
Podunk Steam Posted October 28, 2020 Report Posted October 28, 2020 (edited) 6 minutes ago, Pigsy said: I don't have replay turned on in escribe for that profile ! Your first post mentions Replay. On 10/27/2020 at 2:05 PM, Pigsy said: I recently bought a Prisma DNA 75c, i have downloaded the Evlolv replay theme on to it. My problem is once it has locked i unlock it and everytime it shows check atomiser from 2 to 5 times then it will fire and be ok until it locks again. I have checked the atty is tight and tried other atties aswell but still does the same thing, I downloaded another theme to check it wasnt that and i am now stumped. Any help would be much appreciated please. Earlier I mentioned room temperature. Your atty and mod should be at room temperature when reading the ohms resistance for the first time the atomizer is connected to the mod. Edited October 28, 2020 by Podunk Steam
Pigsy Posted October 28, 2020 Author Report Posted October 28, 2020 3 minutes ago, Podunk Steam said: Your first post mentions Replay. Yes i dowloaded the theme so i had replay if i wanted to use it but in the watts profile i use for n80 i disable replay, Sorry for the confusion will edit post.
Podunk Steam Posted October 28, 2020 Report Posted October 28, 2020 7 minutes ago, Pigsy said: Yes i dowloaded the theme so i had replay if i wanted to use it but in the watts profile i use for n80 i disable replay, Sorry for the confusion will edit post. No worries, with so many variables I try to take in all information. My best guess at this point would be a cold or incorrect solder joint. I'm not familiar with this particular mod and its construction as to be able to look at the solder work done. As well as making sure your coil connections are firmly fastened may avoid looking into the mod itself. 1
Pigsy Posted October 28, 2020 Author Report Posted October 28, 2020 9 minutes ago, Podunk Steam said: No worries, with so many variables I try to take in all information. My best guess at this point would be a cold or incorrect solder joint. I'm not familiar with this particular mod and its construction as to be able to look at the solder work done. As well as making sure your coil connections are firmly fastened may avoid looking into the mod itself. Im not the best person to be able to explain a problem and should of put in more information, i have heard of a cold solder joint in the past, hoping its not that. i have attached a picture ( hopefully it works) of the mod. Shame because its a great mod. Thank-you for your time 😊 C0291407-B97A-4676-AE09-C50C68A7D769.webp
Podunk Steam Posted October 28, 2020 Report Posted October 28, 2020 8 minutes ago, Pigsy said: Im not the best person to be able to explain a problem and should of put in more information, i have heard of a cold solder joint in the past, hoping its not that. i have attached a picture ( hopefully it works) of the mod. Shame because its a great mod. Thank-you for your time 😊 C0291407-B97A-4676-AE09-C50C68A7D769.webp 5.13 kB · 2 downloads I didn't read into the thread but it may help you being it states resistance issues. I'm familiar with the look of these mods and it's a subjective thing.
