DaveK Posted May 22, 2020 Report Share Posted May 22, 2020 So, I just got the new Lostvape Centaurus, and it's fantastic. First DNA mod. So far I've only been using the Replay profile, with ss316l triple fused dual claptons at .10 ohms. Works great mostly, but occasionally it seems like Replay just completely loses its shit and will just keep ramping up harder until it dry hits. If I cancel and reset replay, it goes back to normal. But when it starts doing that, it just keeps hitting way too hard til I cancel it and set it again. Help please! Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 22, 2020 Report Share Posted May 22, 2020 Using Device Monitor in EScribe will show quite a bit of information. Check the boxes for cold ohms, live ohms and power and post some screen shots of this happening. The Snippet Tool in Windows works well for capture. An example here, not replay but still good example. Link to comment Share on other sites More sharing options...
DaveK Posted May 22, 2020 Author Report Share Posted May 22, 2020 I'll try to do that at some point soon. The difficulty being that I'm not usually around my computer. But I'll post it once I'm able to. Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 22, 2020 Report Share Posted May 22, 2020 Most likely there is some resistance change going on that shouldn't be. Could be loose post screws in atty, bad connection between the 510's . You said dry hits, would burnt hits be a better description? It's hitting much harder right? Take note as to whether you cold ohms is changing, Of coarse coil must have cooled to compare. Link to comment Share on other sites More sharing options...
DaveK Posted May 22, 2020 Author Report Share Posted May 22, 2020 Definitely dry hits. No burned cotton, just firing way too high for the build all of a sudden. It's as if it forgets to regulate the hit and just keeps ramping up way past the wattage it's set to hit to. And quite quickly too. Almost like it would be if I had the atomizer on a series mech. I'm definitely not new to regulated mods, or building my coils. Just new to DNA powered devices. And when this happens (it's only happened twice so far) it's as if I had the mod set on bypass or something, but with a bit of a ramp up curve. And my post screws and connections are definitely tight. For the record, I'm using a Vandyvape Kylin V2 with AVS 28x3+36 ss316l triple fused clapton dual coils, 5 wraps 3mm id sitting at 0.1012 ohms cold. On a Lostvape Centaurus dna250c with Samsung 25R batteries fully charged. Link to comment Share on other sites More sharing options...
DaveK Posted May 22, 2020 Author Report Share Posted May 22, 2020 (edited) But as I said, I'm completely new to DNA mods. Had this one for three days total now, still learning how to use escribe. Haven't changed any settings so far. Using it out of the box with stock theme. Edited May 22, 2020 by DaveK Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 22, 2020 Report Share Posted May 22, 2020 You might try locking the ohms. It only locks the cold ohms. I doubt that I have ever done it myself, it will maybe let it work properly for now. Well almost properly, I consider locking the ohms kind of a work around and not solving the actual problem. You should be able to do that without a computer depending on the theme. Link to comment Share on other sites More sharing options...
DaveK Posted May 22, 2020 Author Report Share Posted May 22, 2020 Yeah, unfortunately the stock theme Lostvape ships these with doesn't have the ability to lock ohms in replay. And I don't really know how to use theme designer quite yet. Honestly, I barely know how to use escribe at the moment. I'll look into doing that when I get home and can get on my computer. Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 22, 2020 Report Share Posted May 22, 2020 There are many themes available for download on this site authored by some pretty sharp folks, 2 Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 22, 2020 Report Share Posted May 22, 2020 Are you using a SS316/316L Temp profile with replay? If so try the wattage profile. Link to comment Share on other sites More sharing options...
Wayneo Posted May 22, 2020 Report Share Posted May 22, 2020 When you start escribe, can you post a snipping of the current profile also. 1 Link to comment Share on other sites More sharing options...
DaveK Posted May 22, 2020 Author Report Share Posted May 22, 2020 1 hour ago, dwcraig1 said: Are you using a SS316/316L Temp profile with replay? If so try the wattage profile. I'm actually using the standard Replay profile, which is wattage based. Link to comment Share on other sites More sharing options...
zark Posted May 22, 2020 Report Share Posted May 22, 2020 @dwcraig1 абсолютно прав (There are many themes available for download on this site authored by some pretty sharp folks,), если Вы уверены в правильной сборке атомизатора, необходимо проверить работу мода на темах других авторов с надежной репутацией Link to comment Share on other sites More sharing options...
DaveK Posted May 23, 2020 Author Report Share Posted May 23, 2020 Quick update for you guys. It seems the coils I was using were of inferior quality. I rebuilt my rta with the wire I usually use, which is quality ss316l wire, and it hasn't happened since. Thank you all for your support and advice! Link to comment Share on other sites More sharing options...
