Molicel P42A Profile
  • 3 weeks later...
  • 1 month later...
@Sn00n00 The Evolv default will work fine. Having an accurate CSV file for your batteries will only make your battery gauge and % more accurate. Battery life will not change. There are two settings that affect battery charge life and they are Cell Soft Cutoff and Charge Mode. Many use 2.75 volts for round cells and 4.2 volts for charge mode. This pretty much gives the most puffs from each charge.
Maybe you can explain more the big NEED.
  • Thanks 1
  • 1 year later...
  • 1 year later...
  On 8/23/2021 at 9:55 PM, Dragan Čelebić said:
I will try to help with the requests.
My settings for Molicel P42 are as follows:
Cell Soft Cutoff: 2.9V
Max Peak Input Current: 28A (1 s)
Max Sustained Input Current: 18A
Max USB Charge Rate: 1.5A
Attachment, my Molicel P42A Profile.
Thanks
Molicel-P42-40-Watt-13.909Wh.csv 280 B · 192 downloads
Hello Dragan I'm sorry to resurrect your answer 1 year later, but the:
caught my attention I wonder why did you decrease them from the default values, please have in mind that my electronic knowledge is low.
Are Those meant to protect the board or the battery?
Thank you in advance, hope to listen from you soon.
Hello Patricio Fernando ..mainly protect the battery cells and contribute to the preservation of the board (my view)
Thank you Dragan, I will adopt your settings, well I will decrease them even more to 25, 15 because I only vape at 42W, and the tendency is to decrease the power even more once I finally get my hands on a fused Clapton 2x32 + 38 ss316.
