Daniel da Rocha Posted April 16, 2020 Report Posted April 16, 2020 Hi Guys, Does anyone have the DNA 75c profile for a 21700 Molicel P42A - 4200mah 30amp battery? Regards, Daniel da Rocha
Wayneo Posted April 18, 2020 Report Posted April 18, 2020 Here's a video showing how you can run and create your own.https://youtu.be/pNsAHmZ-E0o?t=0 All you need is an RDA , a couple loops of wire, a fan, and an hour of your time. There's no longer a Watt hour setting on color boards.
Barbara Posted May 5, 2020 Report Posted May 5, 2020 Can anyone share their results? I live with children and I don't have a space to test my batteries without them running around.
retird Posted May 6, 2020 Report Posted May 6, 2020 I have not seen any posts showing what you desire... I searched this forum in April when this thread started... If you run and create one you might post your results...
Barbara Posted May 6, 2020 Report Posted May 6, 2020 That's the thing, I CAN'T run the test myself due to kids running around all day.
retird Posted May 7, 2020 Report Posted May 7, 2020 Well then I hope somebody here has run the test and WILL HELP ya out...
Sn00n00 Posted June 18, 2020 Report Posted June 18, 2020 Bump. For the life of me I cannot get the battery analyzer to work correctly. I NEED this profile, ugh!!!
Wayneo Posted June 18, 2020 Report Posted June 18, 2020 @Sn00n00 The Evolv default will work fine. Having an accurate CSV file for your batteries will only make your battery gauge and % more accurate. Battery life will not change. There are two settings that affect battery charge life and they are Cell Soft Cutoff and Charge Mode. Many use 2.75 volts for round cells and 4.2 volts for charge mode. This pretty much gives the most puffs from each charge. Maybe you can explain more the big NEED. 1 1
Dragan Čelebić Posted August 23, 2021 Report Posted August 23, 2021 I will try to help with the requests. My settings for Molicel P42 are as follows: Cell Soft Cutoff: 2.9V Max Peak Input Current: 28A (1 s) Max Sustained Input Current: 18A Max USB Charge Rate: 1.5A Attachment, my Molicel P42A Profile. Thanks Molicel-P42-40-Watt-13.909Wh.csvFetching info...
Droid Kung Posted October 19, 2022 Report Posted October 19, 2022 (edited) . Edited October 19, 2022 by Fernando Patricio Forgot the citation, I'm sorry, please delete
Droid Kung Posted October 19, 2022 Report Posted October 19, 2022 On 8/23/2021 at 9:55 PM, Dragan Čelebić said: I will try to help with the requests. My settings for Molicel P42 are as follows: Cell Soft Cutoff: 2.9V Max Peak Input Current: 28A (1 s) Max Sustained Input Current: 18A Max USB Charge Rate: 1.5A Attachment, my Molicel P42A Profile. Thanks Molicel-P42-40-Watt-13.909Wh.csv 280 B · 192 downloads Expand Hello Dragan I'm sorry to resurrect your answer 1 year later, but the: Max Peak Input Current: 28A (1 s) Max Sustained Input Current: 18A caught my attention I wonder why did you decrease them from the default values, please have in mind that my electronic knowledge is low. Are Those meant to protect the board or the battery? Thank you in advance, hope to listen from you soon.
Dragan Čelebić Posted October 19, 2022 Report Posted October 19, 2022 On 10/19/2022 at 1:34 PM, Fernando Patricio said: Hello Dragan I'm sorry to resurrect your answer 1 year later, but the: Max Peak Input Current: 28A (1 s) Max Sustained Input Current: 18A caught my attention I wonder why did you decrease them from the default values, please have in mind that my electronic knowledge is low. Are Those meant to protect the board or the battery? Thank you in advance, hope to listen from you soon. Expand Hello Patricio Fernando ..mainly protect the battery cells and contribute to the preservation of the board (my view)
Droid Kung Posted October 19, 2022 Report Posted October 19, 2022 On 10/19/2022 at 1:51 PM, Dragan Čelebić said: Hello Patricio Fernando ..mainly protect the battery cells and contribute to the preservation of the board (my view) Expand Thank you Dragan, I will adopt your settings, well I will decrease them even more to 25, 15 because I only vape at 42W, and the tendency is to decrease the power even more once I finally get my hands on a fused Clapton 2x32 + 38 ss316.
Droid Kung Posted October 19, 2022 Report Posted October 19, 2022 On 10/19/2022 at 1:34 PM, Fernando Patricio said: Max USB Charge Rate: 1.5A Expand I have one more question Dragan, where do we set this config? And yet if you have time, I would like to discuss with you, the output values, because I vape at so low wattage that the default values look to me way too high
