skineedog Posted January 3, 2020 Report Posted January 3, 2020 Anyone have an idea what would cause a 250C to not turn on until a usb is plugged in? The problem seems to be intermittent but usually occurs after the mod has been sitting for a while. Once plugged in, it powers on and functions fine. After it has sat idle for a while, several hours, it will require being plugged in again.
dwcraig1 Posted January 3, 2020 Report Posted January 3, 2020 58 minutes ago, skineedog said: Anyone have an idea what would cause a 250C to not turn on until a usb is plugged in? The problem seems to be intermittent but usually occurs after the mod has been sitting for a while. Once plugged in, it powers on and functions fine. After it has sat idle for a while, several hours, it will require being plugged in again. https://forum.evolvapor.com/applications/core/interface/file/attachment.php?id=235932 (US) https://forum.evolvapor.com/applications/core/interface/file/attachment.php?id=235933 (INT) Some folks have reported good results with this firmware, I'm thinking more is going on other tan a fw problem but just my thoughts. Paste the fw in your fw folder during the fw update process . Or Appdata/Roaming/Evolv/EScribe Suite/Firmware/DNA Color 250
skineedog Posted January 6, 2020 Author Report Posted January 6, 2020 Nope... doesn't solve the issue for me.... Guess it's time to submit a ticket. 1
Nori Posted March 6, 2022 Report Posted March 6, 2022 (edited) I have the same problem, when I change the batteries my thelema won't power up until I plug it to a usb power source even though it has fully charged batteries inside Edited March 6, 2022 by Nori
Wayneo Posted March 6, 2022 Report Posted March 6, 2022 @Nori Is your mod running the latest service pack (EScribe Suite 2.0 SP31) ? The link is in my signature line. You can then install SP45 on your mod. You can tell the SP on your mod by starting escribe with your mod plugged in, then click Device Monitor. It's down in the bottom right hand corner.
Nori Posted March 7, 2022 Report Posted March 7, 2022 @wayneo yes i'm running firmware 1.1 service pack 45. I updated my device right after I received it 4 months ago and this problem only appeared last week.
Wayneo Posted March 7, 2022 Report Posted March 7, 2022 8 hours ago, Nori said: I updated my device right after I received it 4 months ago and this problem only appeared last week. Then no idea. I find it odd that everything worked just fine for 9 weeks. Grasping for ideas, did anything change shortly before this started; new batteries, leaking from an atty, anything you remember changing on the mod. If no one else has any ideas you should open a Help Desk ticket. Link in my signature line.
