Habubi Posted August 19, 2019 Report Share Posted August 19, 2019 The device sitting on 4% battery without any work ٢٠١٩٠٨١٩_١٤٣٧٢٢.mp4 Link to comment Share on other sites More sharing options...
retird Posted August 19, 2019 Report Share Posted August 19, 2019 There is nothing in your video.... Link to comment Share on other sites More sharing options...
Habubi Posted August 19, 2019 Author Report Share Posted August 19, 2019 Link to comment Share on other sites More sharing options...
retird Posted August 19, 2019 Report Share Posted August 19, 2019 Seeing Check Battery message. Take out the batteries and check the voltage of each battery with a meter. What is the voltage of each? Have you got another set of batteries to try? When batteries get too low they will not charge inside the device. Any more information you can give? Link to comment Share on other sites More sharing options...
Habubi Posted August 19, 2019 Author Report Share Posted August 19, 2019 Is this information enough? Link to comment Share on other sites More sharing options...
retird Posted August 19, 2019 Report Share Posted August 19, 2019 With fully charged batteries in the device what are the voltage readings and % of charge showing in Device Monitor within EScribe? Link to comment Share on other sites More sharing options...
Habubi Posted August 20, 2019 Author Report Share Posted August 20, 2019 (edited) https://youtu.be/AN-6_S1RzIk Edited August 20, 2019 by Habubi Link to comment Share on other sites More sharing options...
Wayneo Posted August 20, 2019 Report Share Posted August 20, 2019 @Habubi Look at cell 2 in your video, that battery is showing like 2.8v (can't tell from fuzzy video, PRINTSCREEN would have been better. Did this just start? Did you have any leaking? Link to comment Share on other sites More sharing options...
Habubi Posted August 21, 2019 Author Report Share Posted August 21, 2019 Changed the battery Link to comment Share on other sites More sharing options...
retird Posted August 21, 2019 Report Share Posted August 21, 2019 Could it be that you have a bad or broken connection in the battery tray or juice leaking onto the board? Can you use a meter and check the voltage at the wires going to input connections going to the board at B- and B+? See diagram in pdf linked here: https://downloads.evolvapor.com/dna250color.pdf Link to comment Share on other sites More sharing options...
c8h10n4o2x2 Posted October 6, 2019 Report Share Posted October 6, 2019 Hi, Had this same issue. Went into Options - User Interface - Clicked Advance. Went to the Mod tab and then the Battery tab and set Type to 2-cell and uploaded the changes. mine shows and accurate percentage now. Hope this helps Link to comment Share on other sites More sharing options...
