Check atomizer
shehabismail
 Share
Hello, I am using a clapton ss316L from advanced vape supply. When I am on replay mode, the first puff i like then i click save puff, then when i fire again it says check atomizer, replaced the coil and still same behaviour. Works fine in wattage mode. When I try SS316 it always says temp protect from the first puff. I am running latest software
I'm guessing that your Clapton SS316L wire is probably not pure stainless. I have some coils I thought were SS316L but the core is A1 Kanthal, Vandy Vape Alien Coil. I couldn't understand why they wouldn't work in TC mode but when I looked Closer I noticed the A1 : [  26ga(A1)*3+30ga(SS316L)  ] . I hope this helps you a little.
3 hours ago, shehabismail said:
It should work even if its contact, my new Vaporesso GEN Works fine with the same build. Also it should work if the wire has SS or any other temp control material...
Many, many posts here about contact coils and DNA technology....  I offer a suggestion to try a spaced coil as many have found this solves their issues.... Good luck...
  • 3 weeks later...
tried spaced coil. same issue. this is so frustrating, same clapton builds work fine on my other dna 200 and 250
The check atomizer message can mean several things.  Maybe the device is built different than the 200 and 250 you have (the 200 and 250 don't have replay either) and there is a connection issue with that atty which will give a check atty message..  Can you put the same coil in a different atty and try it? Note that some atty's don't play well with replay..... here is a link if you choose to visit.....  your atty may, or may not be one shown that doesn't play well with replay...  https://forum.evolvapor.com/forum/42-replay-and-atomizers/
 Does it work just fine while vaping in TC mode on the 250C?
Atty works fine on other DNA devices in SS316L Temp control.
I'll ask again:   Does it work just fine while vaping in TC mode on the 250C?
I'll ask again:  Can you put the same coil in a different atty and try it on the 250C in TC and Replay modes?
The 250C is different than the 200 and 250.......
Please comment after you do these things....
 Share
