jinx'd Posted May 31, 2019 Report Posted May 31, 2019 I need a few measurements. center to center for each of these. between the 2 small buttons. between the fire button and one of the smaller buttons. I need to see if this will fit a box I have, but I want to be sure. thanx
dwcraig1 Posted May 31, 2019 Report Posted May 31, 2019 https://downloads.evolvapor.com/dna75.pdf mm of coarse
jinx'd Posted June 1, 2019 Author Report Posted June 1, 2019 thanx. yeah, I seen that. it shows every measurement , except for what I am looking for.
dwcraig1 Posted June 1, 2019 Report Posted June 1, 2019 How about something like this? These boards are slightly longer because of the balance tap but otherwise the same as a DNA75 1
jinx'd Posted June 1, 2019 Author Report Posted June 1, 2019 ok, excellent, I now have 1 measurement = the 10.2mm. now what I need is the distance between the 8mm button and a 4mm button. now, this doesn't need to be an absolute spot on measurement. calipers and eyeballing will get the job done. thanx.
jinx'd Posted June 1, 2019 Author Report Posted June 1, 2019 AWESOME ! you gave me exactly what I needed, I just had to look a little closer . I have a bricked 300w DotMod. the screen is torn from its ribbon, ribbon is soldered to the chip. I bought it this way, not knowing it was torn. it looks like a DNA75 chip will fit . I will just have to custom Mount it, not a real problem. thanx a ton man 😃
jinx'd Posted June 1, 2019 Author Report Posted June 1, 2019 oh, I should clarify. idk if it is "bricked", it very well, even probably, works. but without a screen, a soldered on screen... well …..
jinx'd Posted June 1, 2019 Author Report Posted June 1, 2019 btw. I know of protovaper. is there any other places to get DNA chips ?
Wayneo Posted June 1, 2019 Report Posted June 1, 2019 Protovapor is solid, I'd just buy from them. Either the 250 or the 75 should fit. But the 250 is wired in series and a minimum of 2 cells. The 75 is a parallel board if using more than 1 cell
jinx'd Posted June 1, 2019 Author Report Posted June 1, 2019 thanx. I am chosing the 75 because = I don't vape over 60w usually, $32 + shipping, whatever that is. and it would be extra work to get 2 18650's in there. so I am think just 1 21700. I can use just 1 cell, right ?
jinx'd Posted June 1, 2019 Author Report Posted June 1, 2019 hope I'm not being a pita. nuther question. would you happen to know where I could get a battery tray with contacts ? btw. I only paid $20 for the DotMod.
dwcraig1 Posted June 1, 2019 Report Posted June 1, 2019 12 minutes ago, jinx'd said: hope I'm not being a pita. nuther question. would you happen to know where I could get a battery tray with contacts ? btw. I only paid $20 for the DotMod. A PM went your way 1
Wayneo Posted June 1, 2019 Report Posted June 1, 2019 26 minutes ago, jinx'd said: I am chosing the 75 because ... I can use just 1 cell, right ? Yes. 13 minutes ago, jinx'd said: would you happen to know where I could get a battery tray with contacts ? Zillions of places, but these are solid https://www.ebay.com/sch/mosmax_electronics/m.html 1
jinx'd Posted June 1, 2019 Author Report Posted June 1, 2019 6 minutes ago, dwcraig1 said: A PM went your way thanx you, sir. but I just got a Paranormal 250c. $112 to my door.
