Hcigar vt75c not performing even close to my triade 250c
Adam_Aves
There are many knowledgeable mods and users here that could help you, you don't need to wait for me.
This could be many things, or a combination of things.
What do you mean "doesn't perform nearly as well" ?
Are they both using the same 'material' file?
Are you sure they're both using ALL the same profile settings?
Do they both read/show a similar coil resistance when cold/ambient temp?
14 minutes ago, Adam_Aves said:
Thanks @Wayneo, I am pretty sure they are exact same material (I will triple check) and the resistance reads the same for the atomizer on both mods. Only difference I could see is room temp is 10 degress or so higher on hcigar.
I was going to try case analyzer in the am
Well don't do like I did a couple of weeks ago. I accepted the setting from atomizer analyzer but fogot to upload to device so I had to do it again.
  • Thanks 1
