Adam_Aves Posted May 23, 2019 Report Share Posted May 23, 2019 Hi @Wayneo, I wanted to ask you. My triade works great in tc ss316l mode. My new hcigar vt75c with the same settings doesn't perform nearly as well. Where should I start with troubleshooting? I noticed room temp is 74 in triade and 84 on hcigar. Link to comment Share on other sites More sharing options...
Wayneo Posted May 23, 2019 Report Share Posted May 23, 2019 There are many knowledgeable mods and users here that could help you, you don't need to wait for me. This could be many things, or a combination of things.What do you mean "doesn't perform nearly as well" ? Are they both using the same 'material' file? Are you sure they're both using ALL the same profile settings? Do they both read/show a similar coil resistance when cold/ambient temp? Link to comment Share on other sites More sharing options...
Adam_Aves Posted May 23, 2019 Author Report Share Posted May 23, 2019 Thanks @Wayneo, I am pretty sure they are exact same material (I will triple check) and the resistance reads the same for the atomizer on both mods. Only difference I could see is room temp is 10 degress or so higher on hcigar. I was going to try case analyzer in the am Link to comment Share on other sites More sharing options...
Wayneo Posted May 23, 2019 Report Share Posted May 23, 2019 17 minutes ago, Wayneo said: What do you mean "doesn't perform nearly as well" ? Are you sure they're both using ALL the same profile settings? I'm a quick learner. I'll only ask 1 question at a time after this. 1 Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 23, 2019 Report Share Posted May 23, 2019 14 minutes ago, Adam_Aves said: Thanks @Wayneo, I am pretty sure they are exact same material (I will triple check) and the resistance reads the same for the atomizer on both mods. Only difference I could see is room temp is 10 degress or so higher on hcigar. I was going to try case analyzer in the am Well don't do like I did a couple of weeks ago. I accepted the setting from atomizer analyzer but fogot to upload to device so I had to do it again. 1 Link to comment Share on other sites More sharing options...
Adam_Aves Posted May 23, 2019 Author Report Share Posted May 23, 2019 Thanks, seems like an easy mistake to make. Link to comment Share on other sites More sharing options...
Adam_Aves Posted May 23, 2019 Author Report Share Posted May 23, 2019 If I load settings from triade (working great) to escribe can I then copy that exact setup (settings) to the hcigar vt75c , (seems that will work just have not tried) Link to comment Share on other sites More sharing options...
