randy mc Posted December 16, 2018 Report Posted December 16, 2018 Hello, I just purchased an E-square. My question is its reading the ohms a bit high compared to my triade 250 and paranormal 75. My triade and paranormal read this atty at .92 to .94 respectively and i can TC at 430f. However my E-square reads the same atty 1.15 and wont go over 230f, I feel like somethings wrong? I mean if i set the TC at 230 it will reach it and go into temp protect mode but if i set it at like 240 it will never reach that temp. Is this too low to vape at? I mean the vape is surprisingly good a bit warm and plenty of vapor but why is the temp so low like 230f when my other 2 dnas will reach 430f with the same atty?
retird Posted December 16, 2018 Report Posted December 16, 2018 Could it be that the 230f you list is 230C... which e-square are you using?
randy mc Posted December 16, 2018 Author Report Posted December 16, 2018 6 minutes ago, retird said: Could it be that the 230f you list is 230C... which e-square are you using? Its the dna 60 esquare. Yes I made sure to check again thats its F and not C. Its just weird that I can get a decent vape on 230f off the same atty and build that my other dnas need 430f to get the same vape. I check internal resistance and its stock .003 The thermal is also stock but I cant imagine that would make it 200f less than my other dnas which are also stock settings. I mean technically its a good vape but just 200f less than my others using same atty and same build...I cant figure it out.
retird Posted December 16, 2018 Report Posted December 16, 2018 hum,.... are the profiles exactly the same except for the temp setting? Are the ohm's locked?
randy mc Posted December 16, 2018 Author Report Posted December 16, 2018 3 minutes ago, retird said: hum,.... are the profiles exactly the same except for the temp setting? Are the ohm's locked? Yes profiles for ss316 are the same on all 3 devices, its the stock one from evolve. I checked to make sure. Ohms are not locked. The only thing I can think is maybe not a cold ohm initial reading? dam if I know. Ill give it a solid 30 mins before I fire it again and ill get back to you.
retird Posted December 16, 2018 Report Posted December 16, 2018 Yep, need to start with cold atty on each device. Select New Atty.....
randy mc Posted December 23, 2018 Author Report Posted December 23, 2018 yes after waiting 45mins it was much closer to the res i expected, thank for your replys
