change max temp from 600º to 950º for enail.
Jay@ADV
 Share
23 hours ago, Wayneo said:
Steam-engine. Wire Wizard. Upper right hand box. You'll see equivalents. Use Nickel. In the lower area of the page, use your actual material. Also it's a good way to use different materials on the DNA40 which only had Nickel.
I think I ended up adjusting a graph from some other wire, can't remember.  Would've been less hassle if the increased temp limit actually worked though, it seems bugged.
Edited by Chris Musampa
 Share
