kalagan Posted October 29, 2018 Report Share Posted October 29, 2018 Hi all, I know this is an issue that others have experienced, but I'm not sure how to solve it and it's driving me mad, it ruins the experience. The device will usually take anywhere between 2/3 min to 15 min or more to wake up from not being used for a while. It has never taken less than 2 min to power on by pressing the fire button, usually I have to press a few times then try again a few minutes later and it might work. It might work, or might not .. It’s really problematic because I might take it to a fag break, and then spend most of the break cursing at it for not powering on when I need it . For a device in that price range it’s really frustrating! What can I do to fix this? I’ve tried reboots, service packs , changing setting in Escribe etc .. nothing works. It always does it, only with a USB cable I can guarantee it’ll wake up when I need it. When it finally does start up and work, it will also always ask me to use Old or New setting, it seems it thinks it's a new coil every time . My serial number is MBPX DBVF CJTM , many thanks in advance for your support! Link to comment Share on other sites More sharing options...
BillW50 Posted October 29, 2018 Report Share Posted October 29, 2018 Wow! No kidding? I have two Paranormal 250C just sitting here on my desk (I have 8 DNAs on my desk now) that I know I haven't touched in a few days, one in a few weeks. And I picked up each one and fired and it fired right up. I do have autolock off on all of my DNAs. You think this might be it? What kind of mod is yours DNA board in? Link to comment Share on other sites More sharing options...
Wayneo Posted October 29, 2018 Report Share Posted October 29, 2018 Which Service Pack are you currently running? I'd suggest you run EARLY SERVICE PACK - EScribe Suite 2.0 SP18, mod firmware version 1.1 SP35 1 Link to comment Share on other sites More sharing options...
kalagan Posted November 3, 2018 Author Report Share Posted November 3, 2018 Thanks for the replies, I've downloaded the latest SP which mentioned sleep status improvement but after a week I confirm it hasn't changed anything. It seemed to do so at first but when I leave it on its own at night it does this again in the morning. @BillW50 I've got a Lost Vape Paranormal 250C device, yeah I also turned off the auto lock but no difference from that. @Wayneo Should I just download this early SP you mention? I doubt it'll maker a difference but I'll try, where do you get previous SP from? Is it possible to just send it back and get one that works correctly? Kalagan Link to comment Share on other sites More sharing options...
Wayneo Posted November 3, 2018 Report Share Posted November 3, 2018 2 hours ago, kalagan said: @Wayneo Should I just download this early SP you mention? I doubt it'll maker a difference but I'll try, where do you get previous SP from? Yes. Escribe software link was/ is also in my signature line Link to comment Share on other sites More sharing options...
kalagan Posted November 13, 2018 Author Report Share Posted November 13, 2018 Thanks a lot Wayneo, I've applied that SP and the issue is fixed! I've waited for a bit to make sure but the mod definitely works fine now. Many thanks again for the support. Kalagan Link to comment Share on other sites More sharing options...
Sid Feng Posted November 22, 2018 Report Share Posted November 22, 2018 @Wayneo I have the same issue kalagan had, and my device was lost vape 133, I think it's DNA 200, how could I fix the issue? Link to comment Share on other sites More sharing options...
Sid Feng Posted November 23, 2018 Report Share Posted November 23, 2018 (edited) 19 hours ago, Sid Feng said: @Wayneo I have the same issue kalagan had, and my device was lost vape 133, I think it's DNA 200, how could I fix the issue? I tried to update the firmware of version '2015-09-30', afterwards installed 'EScribe SP18' to replace the old one, and follew the advice to update the service patch SP5, finnally the issue fixed. Whenever I click firebotton to wake up it, do need to select new coil, it works perfect. Edited November 23, 2018 by Sid Feng Link to comment Share on other sites More sharing options...
Sid Feng Posted November 27, 2018 Report Share Posted November 27, 2018 After updated to the lastest version, don't need to select new coil now. Link to comment Share on other sites More sharing options...
