ibanezcollector Posted October 18, 2018 Report Posted October 18, 2018 So I had an old triade which was so battle worn it was a mess, but the chip still worked flawlessly. So I bought a new case and was going to swap the old board into it, I followed all the wiring seen in the attached photo, and when I go to fire it up, the Lost Vape logo flashes then nothing. When I connect to Escribe it registers the device but when in the diagnostics it shows cell 1 with no power. I did change it to 2 battery mode and uploaded the settings. Still nothing. I double checked and rechecked the wiring. Nothing seems to be shorting or anything like that so I am at a loss right now on what is wrong. By the way this is my first post here, but a long time DNA user. Thanks Brett
JTree Posted November 19, 2018 Report Posted November 19, 2018 Personally, the first thing I would check is to make crazy sure the tabs on the sled were making fantastic contact with the batteries. I can not tell you how many battery sled tabs have been off center enough to rest on the flame jacket of the battery instead of the actual posts. Next, I would look for cold joints on the tabs. Not as likely in my experience, but hey, anything is possible, right? Next, look at the solder joints on the board. Still, not likely you fubbed it, but just make sure. I've had a few weird board failures switching boards around, so if all else fails, reach out to evolve.
JTree Posted November 19, 2018 Report Posted November 19, 2018 Looking at the pictures, that contact at the bottom right....that guy looks like it might give you issues. Also, where are the actual power wires? I honestly don't know if the board using the power wires when reading the different cells (I doubt it), but I'd also try hooking up the juice before reaching out to evolv.
MrZero48 Posted November 10, 2021 Report Posted November 10, 2021 On 10/19/2018 at 6:09 AM, ibanezcollector said: So I had an old triade which was so battle worn it was a mess, but the chip still worked flawlessly. So I bought a new case and was going to swap the old board into it, I followed all the wiring seen in the attached photo, and when I go to fire it up, the Lost Vape logo flashes then nothing. When I connect to Escribe it registers the device but when in the diagnostics it shows cell 1 with no power. I did change it to 2 battery mode and uploaded the settings. Still nothing. I double checked and rechecked the wiring. Nothing seems to be shorting or anything like that so I am at a loss right now on what is wrong. By the way this is my first post here, but a long time DNA user. Thanks Brett Hello brother, I want to change my VTBOX250 battery from 3s Li-Po to dual 18650. Does this diagram that you attach can work on my modification? And does the problem that you facing is already solve? Thanks ...
Wayneo Posted November 10, 2021 Report Posted November 10, 2021 13 hours ago, MrZero48 said: I want to change my VTBOX250 battery from 3s Li-Po to dual 18650. Does this diagram that you attach can work on my modification? Yeah, that will work 👍
MrZero48 Posted November 16, 2021 Report Posted November 16, 2021 On 11/11/2021 at 1:23 AM, Wayneo said: Yeah, that will work 👍 the problem that you facing is already fix? And how thick the cable that you use for this modification? Thanks ...
Wayneo Posted November 17, 2021 Report Posted November 17, 2021 @MrZero48 I only commented on what I quoted. I am/was not the OP (original poster). Focus. The datasheet with wiring diagrams and sizing is here https://downloads.evolvapor.com/dna250.pdf
