marra Posted July 20, 2018 Report Posted July 20, 2018 Hi, If possible can someone please post their case thermal settings for the VT250S I've looked everywhere and can't find anything and I don't have the tools to test it with case analyzer. Any help is appreciated. Thanks.
Wayneo Posted July 20, 2018 Report Posted July 20, 2018 1 hour ago, marra said: and I don't have the tools to test it with case analyzer What tools?
marra Posted July 20, 2018 Author Report Posted July 20, 2018 I thought some kind of attachment was needed thats fits on top of the mod to run the tests? I've just been looking around and seen people making them from a RDA is it as easy as it looks? just run 4 lengths of kanthal and run the test? thanks for the reply.
Wayneo Posted July 20, 2018 Report Posted July 20, 2018 All you need is a stable temperature and your batteries 25-50% full. No atty required to be attached. Oh, and a couple hours ~2-3 max. 1
marra Posted July 20, 2018 Author Report Posted July 20, 2018 2 minutes ago, Wayneo said: All you need is a stable temperature and your batteries 25-50% full. No atty required to be attached. Oh, and a couple hours ~2-3 max. Thanks mate I didn't realise it was that easy, I'll give it a go and post back the results to save anyone else the time, Thanks again.
retird Posted July 20, 2018 Report Posted July 20, 2018 And make sure the mod is at room temperature to start..... I let mine set overnight.... 😊 1
marra Posted July 29, 2018 Author Report Posted July 29, 2018 Thanks for everyone's help I finally managed to run the analyzer the batteries just wouldn't run down, I hope this helps someone else.
Wayneo Posted July 29, 2018 Report Posted July 29, 2018 Good job. While others certainly can use your settings, IMHO they're unique and accurate for your setup. On 7/20/2018 at 12:55 PM, Wayneo said: and your batteries 25-50% full 3 minutes ago, marra said: the batteries just wouldn't run down It's looking at how well your mod heats/cools in the enclosure with your batteries. If you read any of the info on the screen during, it was showing different charging rates and the rise/fall of temperature How long did it take you? Was it 2-3 hours, and 3 button presses (Start, accept, upload)?
marra Posted July 29, 2018 Author Report Posted July 29, 2018 (edited) On 7/20/2018 at 5:55 PM, Wayneo said: All you need is a stable temperature and your batteries 25-50% full. No atty required to be attached. Oh, and a couple hours ~2-3 max. Great, Batteries where between 25-50% and I left it whilst I did other things but it was definitely at least 2hrs and no more than 3hrs when I went back to check and it was as you said (Start, accept, upload). I did notice the info on screen but I didn't really understand it tbh but I have 3 other dna mods 1x DNA75 and 2x DNA200 which I just copied the settings from other users, I was thinking of running the analyzer on those but Is there any need to do this or are other users settings generally correct for everyone? Thanks again for your help. Edited July 29, 2018 by marra
Wayneo Posted July 29, 2018 Report Posted July 29, 2018 28 minutes ago, marra said: Is there any need to do this or are other users settings generally correct for everyone? Considering it's using YOUR batteries along with the internal board temperature sensor during the calculations, I do my own yearly. If you're just a regular power user, not as big a deal. But it's so dead easy, why not. Do 1 of your 200's and look at your results, and decide if you want to do the others. And, you're welcome. 1
