Shaggz Posted July 19, 2018 Report Posted July 19, 2018 mod was working perfectly fine then all of a sudden went from 80%ish battery to 0%. Escribe is showing cell 1 at 4.63v, cell 2 bouncing between 1.69 and 3.02v and cell 3 4.72v. plugged in the screen shows 0% battery no lightning bolt for charging, 4.77v 0.00a. is my battery toast? just odd it went from perfect to done. i emailed vaporshark
retird Posted July 19, 2018 Report Posted July 19, 2018 If I recall that device has a daughter board for charging.... separate from the dna 200 board.... You might also contact Vapor Shark about their daughter board.....
DNA_all_day Posted October 10, 2018 Report Posted October 10, 2018 So im on my fourth vapor shark and I am familiar with this problem. It's because the voltage limiter on the logic board is reading incorrectly. In escribe if you go to the help tab and then click about and then click the evolve logo 7 times then go into your device monster you will have a new option called the "ban gap". That should be around 1v give or take a couple houndreths. Also are you using the 950 or the 900mah lipo? And last but maybe most important, what is your soft cell cutoff set at in the battery tab. If you hadn't messed with it it should be at 3.2 but I've seen them come out of facctory at 2.8 more than a few times. Hope I could help
DNA_all_day Posted October 10, 2018 Report Posted October 10, 2018 oh yeah one more thing. The lipos never just give out suddenly. It just starts deteriorating faster and faster
Spector NS5 RD Posted October 10, 2018 Report Posted October 10, 2018 @Shaggz You need a new board. If any cell reads higher than 4.20v that indicates an analog front end failure (responsible for battery monitoring and balancing). VS has great customer service. Every time I've dealt with VS's customer service, they have always been helpful. Unfortunately, given the board is a proprietary board from Evolv made for VS, VS is the only authorized company allowed to replace the board. If the device is out of warranty there may be a small board replacement charge.
DNA_all_day Posted October 16, 2018 Report Posted October 16, 2018 I've worked with vapor shark and let me guess. Your getting a warranty service error?
