Dna 200 won`t charge
Martyric
Hello, i just got a used Lost Vape Halcyon and i cant get i to charge. I have tried the Usb recovery thing a couple of times, but nothing seems to work .
And i cant seem to find a replacment battery in Europe without having to change the xt contact .
The easiest way is to charge each cell separately, you can connect to each cell by using two adjacent pins on the balance connector, 1 mm solid core hook up wire like that used  with bread boards is ideal for this.  Here is a picture of some hook  up wire soldered to disc magnets to in place, but you could just let the springs on the charger hold it in place, there are several layers of tape over the positive terminal of that old 18500 battery, you could use anything that fits in the charger and will not conduct, a piece of plastic or wood would be even better.
ETA you can do this with the battery connected, but don't use the mod while doing it.
